Question about Kenmore 15762 Dishwasher
Water leaking out bottom of dishwasher door onto kitchen floor.
Both kitchen sinks are clear but dishwasher is still leaking.
  • Kenmore Master
  • 528 Answers
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Posted on Jan 01, 2010
For no apparent reason that I can seem to find, the dishwasher periodically has the bottom full of water. It is not that a cycle was interrupted. It happens between uses. It is clean water and does not...
You seem to have a leaking inlet solenoid valve. It could be a bit of dirt stuck across the seats but it could also be the valve seats that have cracked or worn. Check the valve and replace it if necessary. It is the first component after the inlet pipe.
Feb 06, 2011 | Whirlpool Dishwashers
When running my dishwasher it overflows and leaks out onto my kitchen floor. Had a plumber in and identified that this issue is not with the plumbing as there are no other issues to the sink.
sounds like you should check the rubber gasket around the door. if it is torn or ripped it will leak. hope this helps.also make sure where the rubber meets when you close the door that it is al clean from dirt and grim. have a nice day
Jan 14, 2011 | Maytag Dishwasher
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Dishwasher does not drain completely and runs out on floor
DIshwasher output is plugged. The drain hose from the bottom goes up and then most times to the drain on the kitchen sink. If the hose is plugged when it attempts to pump water out to the drain, it may find a weak spot ( usually where the hose clamps to the bottom of the dish washer ). Thus the water on the floor.
FIRST DISCONNECT POWER ----- then:
You will need to remove debris at the bottom ( inside ) and remove the kickplate and look to where the hose is attached, for leaks and tighten the hose clamp. If you have paper/plastic/ etc. IN the hose you may have to remove the hose enough to clear the plastic tubing. You can try air or a snake.
It could even be something as a bad output tube ( cracked, worn, mouse eaten hole...etc ). or your kitchen sink is plugged causing this too,to be plugged.
Good Luck
Dec 17, 2009 | ON-Q Home (363486-01) (36348601) Expansion...
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore ultra wash dishwasher model665
You have a restricted drain in your sink, not the dishwasher. Water is unable to go down drain fast enough and is backing up.
Nov 13, 2007 | Dishwashers
Kenmore 15762 Dishwasher Logo
295 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
