Question about Radio Communications
I want instructions manual for netset scanning receiver pro 44
  • arifi Mar 02, 2009
    • Netset pro 44,scanning receiver
  • 35 Answers
Its the same as a Realistic PRO-44. Online instructions are here and can be copied and saved.
Posted on Mar 26, 2009
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
Lost web interface otherwise system is working
This does happen occasionally but is not a typical thing. This means that you have either lost network access to the system or a service on the system has stopped. The system will have to be rebooted to get things going normally again. The preferred method (since you can do it through netset) is to connect to the console port with a DB9 straight through serial cable and open hyperterm or putty and connect to it at 9800, 8, 1 none settings. Hit ctrl r and the system will reboot. if you don't have a serial cable then you are forced to pull the power or switch it off and then back on. CAUTION: you risk a database corruption every time the system loses power without closing the database properly (netset or ctrl r through the console) so do this as a last resort. Also, the system will do a disk scan (except V3001) and will take 15 to 45 minutes to complete before the system will start to function again. DO NOT UNPLUG IT AGAIN WHILE IT IS DOING A DISK SCAN! You can tell if it is doing the scan by looking at the S1 and S2 lights on the Call Processor. During a disk scan, they will be alternating back and forth (like police lights). Wait for it to complete and try netset again. I recommend doing a fresh reboot through netset after it comes back up just to be sure it's a fresh clean boot.
Jan 10, 2014 | 3Com NBX V3000 IP Phone
I need a users manual for a Brinks timer model 44-1010 any idea where I can find one?
Go to waterheatertimer.org/pdf/Brinks-44-1010-manual.pdf Make sure "b" in Brinks is a cap.
Feb 02, 2011 | Hampton Technologies Brinks Timer
Need to know how to program netset scanner
I have a 10 channel netset scanner and I would like to know how to program it.
May 17, 2010 | Office Equipment & Supplies
Brinks model 44-1050 digital outlet timer- I don't know how to program it-lost instructions HELP!
I have an instruction for a Brinks 44-1030 which I believe programs the same. If you email me at tedban@gmail.com I will send you a PDF scan of the instruction.
Dec 11, 2009 | TORK Hardware & Accessories
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
JC Penny's women Armitron pro sport model 44/1001 instructions
I'm trying to fix the time on my watch which is the Armitron Pro Sport 44=1001 Womans.
I am looking forward to your solution.
Mar 09, 2009 | JCPenney Armitron Sport Link Bracelet...
Radio Communications Logo
2,098 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
