Question about Weather King 10AJA3601AH Air Conditioner
What wires go to what when replacing a inducer. the man cut the wires instead of taking it off right. the new inducer has different colored wires. two orange,one with stripe and a black wire which is a ground but i dont know where at on the bored it goes to
  • Ken Bledsoe May 11, 2010
    I am not understanding inducer can you describe the inducer.
    Problem Solver:
  • 18 Answers
I would get an electrician or an HVAC tech to hook up this unit ,you do not want to get electricuted or blow up the unit it will cost you more to replace the unit if you blow it up that to get the proper person. REMEMBER SAFETY FIRST.
Posted on Mar 04, 2009
Wiring pigtail input speed sensor on my 2000 sonata. The new plug came with three white wires but the wires from car are different colors. color wiring diagram ?
the connector is the same on both the old harness and the new pigtail. As long as you orientate the connectors the same way you just match up the wires. let me try to explain it this way. If you hold the old connector so the part that holds the connector to the sensor is facing up. Hold the new connector exactly the same way. cut the left wire on both and connect the new connector wire to the old wiring harness. Then cut the center wire and connect them. then cut the right wire and connect. No wiring diagram needed.
One thing I will add is to stagger the new connections. Meaning do nut cut them at the place. Cut one wire then cut the next about an inch or so further and then cut the next about an inch or so further than that. This will prevent the new connections from potentially shorting to each other and will keep the harness from becoming really bulky with all the but connectors in the same location.
Oct 02, 2015 | Cars & Trucks
Smps colour
Okay; first off an SMPS is any number of power supplies used for electronics. So this is a very vague question. In a computer power supply to an IBM or PowerPC based motherboard (the later is now obsolete and no longer in use for most new computers) there is no one power supply "wire". Most video cards are powered via PCI port through the motherboard power supply connection.
Some very high power high end video cards and some SLI/Bridged cards require their own power source and this is usually a 12 volt rail much like the ones used for SATA power supply.
In a monitor, each make and model can be different depending on who supplied the power supply. The internal power cords can come in different colors. Though the standards are black white blue and green and red. Most displays don't use colored cords for connecting to the main board of the display. They use a 8 or 10 pin ribbon. Most of the colored wires are linking the main inducer to the LED back light.
If we're talking about the internal workings of an SMPS (Switch Mode Power Supply) there is no "display" wire. SMPS internal wiring is all about controlling and routing power to the different rails (that is the different power connectors). Never open an SMPS case, especially if it's plugged in. Switch-mode power supplies have capacitors that can provide a rather nasty charge, and several inducers that can hold a charge well after the power supply has been unplugged. Never service an SMPS on your own, always seek a professional when attempting to fix an SMPS. Though, for the most part, fixing a burnt out power supply is a waste of time, it'd be best just to buy a new one and recycle the dead one.
Oct 11, 2013 | Computers & Internet
Fix 3way switch
Feb 2013
1) Copy following link for 3-way switch wiring
http://waterheatertimer.org/How-to-wire-switches.html#3-way
http://waterheatertimer.org/images/Switch-quick-connect-400.jpg
2) Usually a bad switch is replaced.
Buy another 3-way switch.
New switch will have 3 screws (plus green ground screw which is not discussed further).
On new switch, 1 screw will be different color from other two screws.
Same thing with old switch: 1 screw will be different color.
Take wire on different color screw and connect to different color screw on new switch.
Other two wires can connect to either screw.
Feb 02, 2013 | Electrical Supplies
Electrical plug on the fuel pump
take it back ...save $$ go to advance will have color code for pump
Aug 16, 2012 | Cars & Trucks
A couple of weeks ago my Goodman furnace went out. It happened to be a big snow storm here in Chicago. So I called my furnance repair co. that i usually use. They charged me $189.00 to come out to check...
If the inducer fan is out of balance that badly, then you will need to replace the inducer anyway....it will shake its self apart....
Me I would have fixed the wire and then ordered a new inducer right a way and then installed it in a few days when it arrived...in is trouble waiting to happen...
Put the wire back on and get a new inducer coming...
heatman101
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
Feb 20, 2011 | Goodman CACF048B2A Air Conditioner
The three wires to the tow lights have been cut, and i cant find where in the harness they are cut can i bypass it all and just rerun new wires?
Yes. But do you have seperate yellow turn signal lights in the rear or do the turn signals work independant of the brake lights? If yes then you need to wire in a taillight converter. It takes your seperate left & right turn signals combines them with your brake lights on 2 wires instead of 3 leaving you with your normal 4 wires in total instead of 5. 1 Left turn & brake light. 1 Right turn & brake. 1 Taillight. 1 Ground. = 4 wires in total. If you dont have seperate rear turn signals just find left turn wire in taillight assembly, Right turn wire & Taillight & a good ground & you are done. On trailer plug yellow is left, green is right ,brown is tailight & white is ground.
Jun 06, 2010 | 2004 Dodge Dakota
I have a 1997 gmc jimmy...my question is to double check myself...isnt this year model take a different color as in the red coolant?
The coolant is orange in color which is totally man made coolant. If totally drained and flushed you can use the old conventional green coolant instead. It does last longer than the oroange junk us men make. Man made cooland evaporates as you may know whereas the old school juice does not
Apr 24, 2010 | 1997 GMC Jimmy
Turn signal wiring was cut
Should only be 2 wires back there. Look at the opposite working side and it will have 2 wires also, one the same color and one a different color. The 2 wires matching in color are your ground wires for each side. Then you have a color for left and another color for right...Good luck
May 07, 2009 | 2003 Harley Davidson FXSTS Springer...
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Weather King 10AJA3601AH Air Conditioner Logo
27 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
