Question about Solis SCDIG-5000 Coffee Maker, Espresso Machine
I have a Solis SCDIG-5000 Coffee Maker. My machine grinds the coffe, compresses it properly, it takes water from the water tray properly, but no coffee is delivered to my cup. The water seems to leak under my machine. The grinded coffee is sent to the discharge untouched. The strange this is that if I repeat this preocess three times, I will finally get some coffee in my cup. Any ideas would be greatly appreciated.
  • 1,089 Answers
Hi
Your boiler is leaking and needs to be replaced. Your first 2 shots are filling the boiler.
Posted on May 24, 2009
My Solis Master 5000 will not make a cup of coffee anymore. I already descaled, the water comes through the steam arm, but not through the coffee drip. How to fix?
If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
Aug 31, 2017 | Solis Coffee Makers & Espresso Machines
I have a solis 5000 and the temperature of my coffe is to low . How can i get o hot coffe ?
Descale it!! any water (even RO) will build up scale. Once a month is good and I use 4x filtered water
Oct 17, 2011 | Solis Master 5000 Espresso Machine
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
I have a solis 5000 coffee maker and would like to descale. the users manual says never use vinegar as it will harn the machine. It recomends a product called SOLIPOL, is there another product that you...
Hi
Starbucks used to carry a descaling product for their machines. Yes don't use vinegar because it is only 5% before you dilute it. It also leaves a taste for about 2 weeks that will affect the taste of your coffee. You can use Citric acid. 1 tablespoon per 32 oz of water. Use at least 2 table spoons. Dissolve the descaling solution so there are no crystals left. Now.
Turn the machine off and then push and hold the 2 buttons at the same time. While holding them down, turn the machine on.
Release the buttons and turn the dial counter clockwise till it stops.
This will keep the machine from heating.
If you push the steam button the pump will activate.
Open the steam knob. Run 8 oz through the wand and rekease the button. Let it set for 10 minutes, then open the knob again. Repeat until the tank is empty. Rinse with a whole tank of fresh water and your done.
If you have the Digital there is a program in the menu for descaling. There is also a program for resetting the descal mode so it will tell you the next time it need to be done. Chose yes and push the enter button. Also change your water hardness to 4. Descale more often than not enough.
Jul 15, 2009 | Solis SCDIG-5000 Coffee Maker, Espresso...
Need to buy water tank of solis pallazzo coffee maker
The only importer of solis I know of is Barratza.com, they will have the parts needed.
May 29, 2009 | Solis Master 5000 Espresso Machine
Solis master 5000 Espresso Maker is leaking
Before you go that far, what does the grind on the coffee puck look like; is it fine like powder or is it course. The water from the machine might not be able to go through the coffee and so the bypass is opening because of too much pressure. Try adjusting grind first.
Mar 24, 2009 | Coffee Makers & Espresso Machines
Machine says warming up
How old is the machine?
Do you descale the machin regulary?
Calcium in the boiler makes this problem, don´t heat up the boiler.
Try to decalcify the machine, if it not will work after that then i think you have to replace the boiler.
Jan 02, 2008 | Solis SCDIG-5000 Coffee Maker, Espresso...
Manual
Here's the link; http://www.solis.com/pdfs/manuals/kaffee/MASTER5000_DIGI/MASTER5000_DIGI_ENG.PDF Hope this helps :)
Jul 02, 2007 | Solis SCDIG-5000 Coffee Maker, Espresso...
Solis SCDIG-5000 Coffee Maker, Espresso Machine Logo
184 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
