Question about Polaroid TLA-04011C 40 in. LCD TV
Loud popping noise
I have a 23" Polaroid CRT TV which is making loud popping noises every 15 minutes or so.
This has no effect on the sound or picture but scares my dog every time.
It seems to come from the left side (as you face the screen)
roger
I'm having an issue with my 40" Polaroid LCD TV making a mysterious popping noise every so often. I'm curious to know what is causing this loud noise. It happens more when the TV is off. Other than the noise, the TV works perfectly fine. Weird.
My sony trinitron a very old model box tv makes a very loud banging sound ever 10-30 minutes on or off. Best way to describe it like a cracking or splitting wood sound. I'm guessing its from the plastic case around the tv its built with. It'll make that sound too when i walk near it and from my movement the vibration triggers the sound. However alot of times when there is no movement or anything it'll just pop so loud it'll scare the heck out of me.
Posted on Mar 04, 2012
  • 1,606 Answers
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Posted on Mar 23, 2009
  • Paul Bade Mar 23, 2009
    The noise in the LCD TV may be coming from the standby power supply or some
    odd transient in the control circuitry is putting a spike turn-on in
    the audio amplifier. It could be the result of a loose connection - maybe your power cord isn't in all the way or you have bad wiring (does a lamp plugged into the same outlet flicker at the same time?) If you can identify more precisely where in the set the noise
    comes from, that would help.
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Loud popping noise and spark coming from red projector
I would guess you have a High Voltage Leak at the Anode Lead Cap where it Mounts to the CRT. This is not a area to mess with You are better off calling a professional to fix it. It may be a little difficult to confirm if it is a intermittent problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 51F59 51" HDTV Projection...
Sounds like a jet taking off
the horizontal output transistor is busted or a protect diode,check the plyback maybe it has a leak
Oct 15, 2008 | Samsung HL-P6163W 61" TV
TV Making a Loud Noise
this can happen with the flyback transformer's brightness which can be adjusted , also the power transformer can make humming or buzzing sounds which can't be adjusted , also this can happen with the picture tube or the CRT board failing , and sometimes chips with heat sinks or the IC's themselfs
Oct 07, 2008 | Symphonic ST420FF 20" TV
Loud sound
Try to reduce your volume, do you use a sound system thats why the sound is very loud?
Apr 16, 2008 | Sanyo DS32224 TV
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Nov 09, 2007 | RCA F32450 32" TV
Polaroid TLA-04011C 40 in. LCD TV Logo
949 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
