Question about Air Tools & Compressors
I have a T31 pinner and the top valve is broke and an N60 15 gauge nailer that needs oring
  • 1,388 Answers
I have been buying Bostitch t31 parts on ebay. Rebuild kit usually about $22 - 39 depending on how luckey you are at bidding. Keep searching on Ebay for other parts for this gun as parts are not available at any longer. The oring kit for the N60 is available at the part number is ORK1, cost under $20. You can also find bargains on ebay. When installing orings us silicone grease. It is available at lowes in the plumbing department. It looks like vaseling. It is used for lubricating orings in faucets. Good luck on your repair project.
Posted on Mar 04, 2009
Dewalt 51256 finish nailer, 16 gauge. Shoots two brads at same time. Using Porter 16 gauge brads. Any suggestions
Replace the trigger valve part # 647956-00 to solve this problem. If you have access to very small orings (2mm x 1.5mm), try replacing the two orings on the trigger valve stem. Dewalt uses vinyl orings on the trigger stem and they fail causing malfunction. Easy fix however and not expensive . Good luck
Feb 24, 2014 | Dewalt D51256K 16 gauge finish nailer kit
Wont fire just releases air
This problem is due to failed orings in the gun and the trigger valve. If you have access to orings, replace all the vinyl orings that feel sticky or like putty (at least 3 in the trigger valve). Finally, make sure that the driver blade moves freely within the cylinder and that there are no jammed nails within the path of the driver.
Feb 04, 2014 | Dewalt D51256K 16 gauge finish nailer kit
Driver on my Grex P635 does not seem to be returning to the ready position
An Oring needs to be replaced... if the driver stays forward its usually in the trigger assembly
Nov 27, 2012 | Grex Headless Pinner P635 Nailer
D51822 plunger will fire (and impact wood) but will not retract enough to grab/push out a nail.
Dewalt nailers have some vinyl orings that fail. Usually found within the trigger valve, headvalve, and between the cylinder and cylinder spacer (white plastic piece). A dewalt nailer with failing orings may not leak air however. The vinyl orings tend to start to crumble and the tacky-crumbling pieces tend to create a seal. Easy way to check condition of the vinyl seals in a Dewalt is to remove the trigger valve and look at the orings on the firing pin/stem (2mmx1.5mm orings). If these two orings are soft and sticky, then orings inside of gun most likely the same. Check band on the outside of the cylinder (part # 390159-00) is what causes piston to return to top. But also check to too tight or too loose piston oring, bent shaft of driver and worn/ broken lower bumper. If all is well with internal parts and piston does not return to top, too much air is leaking past nose of gun. Oring kit sold by dewalt will contain most of the orings needed. The kit may not have orings for the trigger. You will at need two orings (2mm x 1.5mm) for the trigger valve stem or just replace the valve. Use white grease or silicone paste lube on all the orings. Good luck.
Nov 10, 2012 | Dewalt Heavy - Duty 31° Clipped Head...
When you pull the trigger air comes out near the trigger and no nail is fired.
The problem that you describe indicates that the orings within the trigger failed. You could replace the orings if you have a source for very small rings (2mm x 1.5 for the firing pin inside the trigger valve) or just replace the whole trigger assembly (under $10). Lube all orings with white grease or silicone paste lube (remove head and lube head valve assembly). Good luck
Oct 11, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
The gun constantly exhausts air when connected to air compressor. Won't build up the pressure when connected. Must disconnect between firing trigger
Easy fix if air is leaking out the top of gun. Remove the head and lube with white grease or silicone paste. If orings seem to be loose, order repair kit from dewalt (you can tighten orings by removing the oring and wind a bit of teflon tape in the oring groove). If air is leaking from the trigger, replace the valve. If air is leaking out the bottom where the nail ejects, pull out the cylinger and lube the orings that seal the cylinder to the body of the gun.
Oct 19, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Air rushes out of trigger area as soon as air hose is connected.
Remove the trigger to expose the trigger valve then un-screw the valve. If you have access to orings, pull apart the valve and replace orings (5 orings in the valve and one external oring ((external oring usually ok)). If you would like to replace the valve complete, the part number is ( PB205ba1) and is available at Good luck with the repair.
Sep 18, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Bostitch T31 air leak thru small head hole
I have repaired hundreds of nailers, however not a t31. I can offer you a few tips on general nail gun repair pertaining to leaks. It is important to check each oring separately if you can to check for proper fit/contact. Do not just replace all orings and then hope for the best. Each oring must fit snugly not too tight not too loose. The surface where the oring contacts must not have fine scratches. Inspect all surfaces with magnify lens for scratches and remove with fine sandpaper. Check each oring for nicks Make sure that gaskets do not block small ports that direct air to headalve. Use silicone grease instead of oil on orings and metal/plastic parts. Lowes sells a small container of silicone grease in the plumbing department. It is used to lube faucet parts. Oil will wash away too fast and sometimes it will swell the orings causing gun to jamb. Finally do not use too much pressure on small nailguns. Try using 70 to 90 lbs. Good luck
Dec 01, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
361 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
