Question about Tomtom XL 330 Car GPS Receiver
I do I set the clock?
I am new at this how do you set the time are clock? on the XL330
  • Anonymous Apr 11, 2009
    How do you set the correct time on the TomTom XL ?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
Tao the map screen tap preferances and continue to tap forward until set clock comes up and then just follow the instruction.
Posted on May 05, 2009
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    Tip
    Procedure For Setting Time Zones For Emerson Clock Radios
    Setting The Time, The First Time
    IMPORTANT: The first time you connect your new SmartSet® clock radio to
    the AC outlet the internal computer will automatically set the time correctly for
    the Eastern Time Zone, which is the initial default setting. The display will
    scan for a few seconds and then show the correct Day and Time in the Eastern
    zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
    clock is set correctly and running.
    If you do not live in the Eastern Time zone you must change the default zone
    display to your own zone. You only do this one time and the SmartSet® will remember
    the new default zone setting and will always return to that setting after a power
    interruption.
    There are 7 time zones programmed into your SmartSet® clock radio as follows:
    ZONE 1 — Atlantic Time
    ZONE 2 — Eastern Time (Default Setting)
    ZONE 3 — Central Time
    ZONE 4 — Mountain Time
    ZONE 5 — Pacific Time
    ZONE 6 — Yukon Time
    ZONE 7 — Hawaiian Time
    To change the default time zone display, depress the Time Zone button.
    The number “02” will appear on the display
    indicating that the default zone is ZONE 2,
    Eastern Time
    on Jun 12, 2009 | Emerson Smartset Clock Radio
    Need to set clock on oven
    Instructions
      • 1
        Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
      • 2
        Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
      • 3
        Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
      • 4
        Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
    Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
    Mar 19, 2011 | Ovens
    How to charge tomtom xl330 gps for the first time ? Is it by using USB from a computer ?
    You can plug it in your car's cigarette lighter socket, or the USB port of a computer,
    Nov 11, 2010 | Tomtom XL 330S GPS Receiver
    How do I get my smart alarm clock to reset itself automatically since the goverment changed the daylight savings time? Or, if I buy a new one will it have the new time changes?
    The Daylight Saving Time settings are not user controlled, so you cannot convert the changeovers to the new schedule - you can only change the time manually. Any new clock or clock radio with automatic settings will work on the new schedule.
    Bill B
    Apr 04, 2010 | Emerson Smartset Clock Radio
    How to set time with new control board?
    You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
    This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
    Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
    Model 1739 answering machine
    Set the clock
    You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
    1. Press and hold CLOCK until the message window displays C and the default day is announced.
    2. To change the day setting, press
    MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
    3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
    4. To change the hour setting, press
    MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
    5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
    6. To change the minute setting, press
    MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
    7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
    8. To change the year setting, press
    MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
    9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
    To check the clock, press CLOCK.
    Jan 08, 2009 | AT&T 1717 Digital Answering Machine
    Emerson smart set clocks
    Sorry it took so long to give you a answer to your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day! Dear Emerson SmartSet® Clock/Clock Radio Owner: Your Emerson SmartSet® Clock or Clock Radio includes Emerson?s patentedAuto Time Setting System that automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and alarm settings for up to 5 years, or even longer. As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/ Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April and ends on the last Sunday in October. The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in March and end on the first Sunday in November. Of course this is a situation that is beyond the control of Emerson, or any other company that produces devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA?s, and many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to make adjustments to the automatic DST software to agree with the new DST timing for 2007. Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows: 1.) On the second Sunday in March you would have to set your clock to the next lower number time zone. For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone 1 to move it ahead by one hour. 2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set your clock back to Zone 02. 3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone. 4.) On the first Sunday in November you would again set your clock back to your correct time zone. Instructions for changing the Time Zone setting are found in the Owner?s Manual. We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
    Oct 26, 2008 | Emerson Smartset Clock Radio
    Emerson Research SmartSet Clock Radio
    There is a solution for this already. You can reprogram the clock to use the new DST settings.
    See http://www.fixya.com/support/t137304-daylight_saving_time_issues
    Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
    Timer
    After you set the time ,do you push the Clock button to lock your time??If you set the clock time and walk away its not holding the time ,because its waiting for you to confirm time selected.So after you set the time press the clock key pad 1 more time .Remember this, just because you bought a new clock doesnt mean its a good part.Bad parts get the best of us ,so dont think your new part is ok yet.It probably is not.
    Aug 16, 2007 | Rangemaster Proffessional 110 Gas Kitchen...
    Tomtom XL 330 Car GPS Receiver Logo
    125 people viewed this question
    Top Tomtom GPS Experts
    Martin Murray
    Will Halftowaite
    Are you a Tomtom GPS Expert? Answer questions, earn points and help others
