Question about Toshiba Satellite 1805-S204 Notebook
Minimizing Screen While Typing
The page automatically minimizes each time I try to use the key board while using Ms Word document. What setting could be causing this to happen? (for Toshiba Satellite 1085-S204)
When I open pages they keep minimizing and I have to resize every time. How can I make the pages stay at normal size
When you open any page restore its size. Then it would open always in that size. This happens normally. In your case, Right Click on the page TOP, there would option of size, set it to normal.
Done.
Aug 02, 2013 | E-Machines eMachines Desktop PC
Tip
Outlook closes when minimized
You might have faced this issue some times while minimizing MS Outlook.
You can solve this issue by doing some changes in MS Outlook.
Step 1: Open MS Outlook and you will see a small MS outlook icon on task bar
Step 2: Right click on it and Unchek the option Hide when minimized
Once you Uncheck the option Hide when minimized, it will look like the pic below
Now you can see the outlook on taskbar even if you minimize.
on Mar 17, 2010 | Microsoft Outlook 2003 for PC
Tip
You might have faced this issue some times while minimizing MS Outlook.You can solve this issue by doing some changes in MS Outlook.
pic below
on Mar 04, 2010 | Microsoft Office Outlook 2003 for PC
Cursor problem,Automatic deleting problem
it sounds like your mouse is highlighting your text automatically. try disabling the trackpad and using a wireless mouse, if that solves your problem then you can adjust the trackpad settings to shut off automatically while you're typing.
Jun 25, 2012 | Computers & Internet
I'm using lenovo g450 and i need to use printscreen but when i press PrntScrn I Don't know if it's ok or it's not working but nothing happens.. but if it's working i don't know where the file stored in...
If you press PRNTSCRN, nothing really happens. You need to paste it in paint in order to see the image. So you have to open Paint (located in Start/Programs/Accessories) and paste (CTRL+V) directly.
Hope it helps.
Thanks!
Feb 02, 2011 | Computers & Internet
Screen keeps minimizing.
Mine does it ,too.Extremely annoying! Just hit Control and 0 and it will go back to normal.
Dec 28, 2008 | Microsoft Windows XP Home Edition
Hi i want to widen my screen
The Resolution can be changed in Windows XP by minimizing all applications, right clicking on the desktop, selecting Properties. In the Display Settings window go to the Settings tab. Here you can change the resolution. I think you are wanting to use a widescreen setup so going for a resolution of 1280x800 should fill your screen. Play around with the available settings to resize the screen.
If you are using MS Vista, you need to minimize all applications to the desktop, right click, select Personalize. In the Personalize Window click on Display Settings down the bottom, modify the resolution as appropriate.
Alternatively, you may be able to find the function key that did this to your resolution. Above your F1-F12 keys there should be a little picture. If you click on the [fn] key (near the Windows key) as well as one of the F1-F12 keys you can cause different functions to be performed. This may be how the resolution changed initially.
Good luck
Apr 23, 2008 | Toshiba Satellite A35-S159 Notebook
Minimize Applications
In order to minimize applications on Nokia N70, you cant press the red key.
You should press menu key twice and try minimizing it.
Dec 01, 2007 | Nokia N70 Cellular Phone
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
Toshiba Satellite 1805-S204 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
