Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer won't agitate, drain or spin
Hi!! My problem is:The Maytag stacked unit LSE7806ACE. Load of towels put in, started load, after filled with water the machine stopped. Took out towels and still wont start. Removed water to see if it was too full. Still wont start but will refill water level. So,the blogs say the could be the fuse,so I need to know how many fuses and location does a Maytag have?Thank very much
Hi Xinia_s
The lid switch needs to be replaced. although it seems to be working for the water intake valves it will not work for the motor. it is not the fuse. the main fuse sits right above the motor's start capacitor in the lower left side of the lower cabinet; had it been the fuse it would'nt even fill w/ water. have the lid switch replaced and it should do the trick.
Posted on May 02, 2009
  • 686 Answers
It only has one block fuse and should be located somewhere close to where the power cord comes into the washer. Go here www.repairclinic.com/SSPartDetail.aspx?s=t-LSE7806A-%3d%3di435797&PartID=435797 this is what you need to check.
Posted on Apr 06, 2009
2 Suggested Answers
SOURCE: Washer won't agitate, drain or spin
LID SWITCH BAD HOW DO I GET TO IT ON LSE7806ACE STACKED WASHER..??
Posted on Aug 04, 2011
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer dryer lse7806ace
Take the belt off the transmission pulley and see if you can turn it by hand. It will agitate on direction and spin when you turn it the other direction.
Put the timer to spin with the belt off and see if the motor will run. There may be a problem in the start switch on the motor letting it start in one direction but not in the reverse direction.
Special tools are required to remove the transmission and brake assembelies. You also want to make sure there is nothing sticking through the holes in the basket causing it to lock up such as a nail or screw that may have been left in a pocket.
Post back with what you find.
Thanks/Mike
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
491 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
