Programme gets stuck on wash cycle
Washing machine gets stuck on wash cycle & won't move onto rinse & spin, it also won't let me put it onto rinse & spin programme so washing machine is sitting with water in it I have already checked the drainage plug & cleaned it out but still doesn't work.
  • Washing Mach... Master
  • 3,361 Answers
Most likely a defective door switch.
Posted on Mar 02, 2009
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Beko washing machine stuck on rinse cycle water I drum but wont move onto spin
all you need to fix your beko
pump fault
or spin problem
i hope this helps
Buy Paul Beer
Jan 11, 2014 | Beko Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Ariston A1435 washing machine. The prgrammes do not move on.Can select any cycle it washes but stays on the programme and does not move onto the rinse cycle have to manually stop and select rinse and spin....
If the program is put ON does the inlet valve open to let water IN. If so does it after the water is filled to the set level go to wash If yes , then after wash does it drain ? If all the above cycle is true then the program is working correct and a fault in the input can be the reason.
If however there is distruption of the sequence, then each input and drive must be checked to establish if the program controller or the input sensors are faulty.
Please give me a feedback
Sep 18, 2010 | Washing Machines
Machien was switched on and put on a normal wash but with 1 min remaining my little boy pushed some buttons and now it is jammed it only needed to spin for a minute but he somehow put it onto no spin. how...
Cancel programme, maybe you have an 'end of cycle' button. Switch machine off & take off plug from the wall socket for 15 minutes. Re-start programme with 'spin only', to rinse out your clothes.
Feb 20, 2010 | Washing Machines
Won't complete wash cycle, stuck at wash after time end!
check heater or thermostat,check is it heat water
if not heat water then heater or thermostat is broken.if you have ohm meter you can check both
,unscrew behind sheet metal and find heater disconnect one wire from it and check it(meter must show some value e.g.30 ohm).
Jul 05, 2009 | Washing Machines
Washing Machines Logo
744 people viewed this question
Top Washing Machines Experts
