How to change and program fax numbers into Savin 3515MF copier
I have a Savin 3515MF fax/copier. I need to program and change some of my fax numbers. The manual does not tell me how. The salesman originally programed when delivered and didn't show me how.
"user tools"
"system Settings"
"key operator tools"
"address book Management"
"Program/ Change" or "Delete"
.......and proceed to make the changes as you wish
All of the manuals can be downloaded here, but they can be difficult to follow.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Posted on Mar 02, 2009
My Savin 3515MF doesn't believe I replaced the toner. I have replaced it a few times, so I followed the same instructions as before but to no luck. HELP!! Please and thank you!
Try cleaning any excess toner from the sensors and any glass inside the same panel as the toner bottle hopper.(the glass slides in and out). Use compressed air around the area where the toner pours into the developer but be careful not to blow out the developer.
Oct 11, 2013 | Savin Copier Supplies; Toner for 3515,...
Change a fax number that is saved
Operator tools.
System Settings.
Administrator tools
Managing the address book.
Choose the user that matches the fax nr. Open the tab fax and change the existing nr.
In the end just save and exit all the way to the copy window
Feb 15, 2011 | Savin 8035e Copier
Have a savin 8035e need to activate fax and scanning
This is the same as the Ricoh MP3500. You can find all the manuals here..
MP3500 manuals
Sep 10, 2009 | Savin Office Equipment & Supplies
Can I scan directly to my computer without having to scan via email with a Savin 3515MF machine?
If you are using XP, click on start, then go into control panel, then to scanners and cameras.
From there select your scanner and follow the directions for scanning.
With vista, click on the start button, then type in scan. There should be an option to "scan a document or picture"
Apr 07, 2009 | Office Equipment & Supplies
Modem fail errors between hp 4345 and savin mfp device
On fax settings set ECM to ON, JBIG to OFF, MAX BAUD RATE to 14.4, V34 to OFF then upgrade to latest firmware and make sure phone line is a 2-line phone line (look plug end of line and there should only be 2 metal strips on connector)
Mar 26, 2009 | HP LaserJet 4345mfp Printer
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Aug 18, 2008 | Office Equipment & Supplies
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
SAVIN 3515MF
open the right door. Open the front cover. Remove the toner assembly, not just cartridge. Unplug wire, pull out.
Mar 12, 2008 | Office Equipment & Supplies
823 people viewed this question
jasbo
jasbo
