Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
TRACTOR BLEW WHITE SMOKE, AND STARTS TO SPUTTER
TRACTOR IS 3YRS OLD 18 HP MODEL. AFTER MOWING FOR ABOUT AN HR,, WHILE AT FULL THROTTLE, GOING UP HILL TRACTOR BLEW A LOT OF WHITE SMOKE FROM THE FRONT END. AND STARTED TO SPUTTER. SHUT IT OFF RIGHT AWAY. CHECK OIL LEVEL AND IT IS FINE. AFTER 5 MIN. RE-STARTED AND SEEMED FINE. NO NEW ENGINE NOISES. DROVE IT DOWN HILL AND ON THE WAY BACK UP HILL AT FULL THROTTLE, BLEW EVEN MORE WHITE SMOKE FOR THE FRONT. LET IT SIT, RESTARED AGAIN AND AT LOW THROTTLE AND DROVE BACK UP THE HILL AND PARKED IT. NEITHER TIME WAS THE MOWER BLADE INGAGED.
  • 110 Answers
Start with making sure your oil lever is not over full. If it is it may be getting into the crankcase breather hose that goes to the carburetor hence the white smoke. Sometimes also you can blow a gasket in the breather system and it will do the same. Check for oil leaks in the breather system. Hope this helps. donnyb60
Posted on Mar 21, 2009
The oil breather hose connects from the crankcase to the carburetor. If the breather assembly on the crankcase gets plugged, oil can be pulled into the carburetor through the breather hose. Try removing the breather assembly from the crankcase and cleaning it in gasoline, followed with a blowout with compressed air. You can also just replace the breather assembly and hose.
Posted on Apr 19, 2009
    Sergeant:
  • Craftsman Expert
  • 417 Answers
You have fuel in your oil. Check the muffler to see if oil is blowing out of it. If so, I recommend a new carb versus installing new parts in an old one. With a tune up and new carb, you essentially have a new motor.
Posted on Nov 21, 2013
18 hp craftsman 2000 smokes when cutting on a side hill
Wanda, make sure oil is not over full, oil in crankcase could be running to the intake of carb., valve guides or piston drenching an excess amount of oil on them causing the smoke. As long as mower does not smoke when driving on near level surface, mower should be OK. These engines were really not designed to cut on steep grades.
2 stroke engines, the engines with gas/oil mix are the mowers that are safe to run on hills as they will not starve or over lubricate engines. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
smoking at an angle
http://www.helpfulgardener.com/forum/viewtopic.php?t=37291
white smoke coming from riding lawn mower exhaust ShopYourWay
Jul 29, 2016 | Craftsman Garden
Tractor blew white smoke started to sputter
Water getting inside of engine.
May 22, 2014 | Garden
My husband bought a 2011 Husqvarna YTH2348. I am the one that mows the grass. We had the mower serviced last week. We have a HUGE lawn and I mowed all but the orchard. The next day, I went out to finish...
Black smoke is generally indicative of a rich fuel system. whitish blue smoke is generally burning oil.
It sounds like there is something wrong with the fuel metering at full throttle. You might check that the mechanical compression release isn't coming on when you go to full throttle.
Aug 17, 2013 | Husqvarna Garden
Brand new less than 30min on tractor when mowing down hill white smoke bellows out the exaust I imediatly shut mower down and am parinoid about restarting for fear of damaging motor.
how steep of a hill was it?steep enough for oil to go forward into the from of the engine roll it to a flat surface and check the oil level if ok run the engine and let it burn off if the hill ii's that steep then stop using it on the hill check the manual for running angles
Jul 10, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
I just bought a briggs 23 hp single cylinde engine and repowered my tractor and having alittle trouble,it has about 4 hours on it, but when mowing uphills it blowing alot of blue smoke, and engine just...
Hello, You have too much oil in it.
Your air filter is most likley soaked with oil and need to be replaced. Are you sure it's a single cylinder?
Hope this helps.
Jul 28, 2011 | Garden
I see a lot of white smoke out of the outlet, what can be the problem i have a 15.5 hp intek ohv motor
1) CHECK THE OIL LEVEL IF IT IS OVER FULL REMOVE SOME OIL TO THE FULL MARK
2) IF YOU MOW ON HILL KEEP THE CARB ON THE DOWN SIDE OF THE HILL
3) WORST CASE RINGS OR VALVE SEALS
Jul 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Murray riding lawn mower Model 425600x8A. Recently, my son and I were using it to mow on a hill when it starting putting out a thick white cloud of smoke. We shut the engine off and let it cool...
The oil entered the cyliders when the mower was tipped at a severe angle. It will clear out after you run it for awhile. Check the oil level to make sure it is full. It could even be overfull and this is what caused the smoke. If it starts to run badly, check the spark plug or plugs. They could get "fouled" from the oil. Change the if the are black or covered with oil. It shouldn't have done any damage to the engine.
Jun 23, 2009 | Garden
14.5hp B&S ohv looses powes & blows white smoke on riding mower
This engine has a badly designed combustion head that causes premature failure of the head gasket. The removal of the overhead cam and head is relatively easy with the engine mounted on the mower. Just remove the hood before you begin. I had the same problem, same symptoms (white oil smoke, mostly when turning or on an inclide-=left side downhill) after the second season of mowing. Made me mad when I got it apart and saw the incredibly stupid head design. Replaced the head gasket and am into my second season with the new head gasket with no more problems but I expect it to blow again at some point. Poor engine design. Easily fixed.
Apr 01, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
2,007 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
