Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
Help setting up bc145xl scanning radio - Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
    Guru:
  • 773 Answers
You have to adjust the squelch. When it scans it will stop when ever the squelch breaks. Start with the squelch turned up a little less then half way, then scan.
Posted on Oct 01, 2009
BC145xl. Where can I get frequencies?
Here's how to program;
How do you program Uniden Bearcat bc145xl
Go to this site and you'll see a U.S.map. Click on your state, then after click on your county and a list of freq's will be there for you.
https://www.radioreference.com/apps/db
Aug 31, 2015 | Uniden Radio Communications
Why won't my BC145XL scan
push manual on the scanner push manual again to see if the channel changes if so then push the scan button , if still no scan see if the volume is turned up. if not turn it up and see if you have any white noise , if you have what is called white noise turn the squelch till the noise is gone then press scan if it still does not scan you may have all the channels locked out and if so they need to be unlocked refer to the manual to know how to unlock channels then try again if that does not work scanner may need to be repaired
Jul 02, 2014 | Uniden BC350C Base Scanner
I have a uniden bearcat bc145xl 16 channel scanning radio, every time I push the manual button, and try to put in a code I can't get all the frequency numbers put in. I don't know what I am doing w
When you press the manual button and then enter numbers it thinks you are entering channel numbers not frequencies.
Try manual button and then prog button.
Then enter the frequencies.
Hope this helps
Aug 18, 2017 | Radio Communications
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
How do I program my bc145xl scanner
I searched but could not find a manual for the BC145XL. Your keyboard looks identical to the UBC144XL though, so the instructions for it should work on your scanner. You can download the manual for the 144 here:
http://www.scribd.com/doc/2056189/UBC144XLT
Bill B
Feb 19, 2010 | Uniden BC244CLT Base Scanner
I have a bc145xl and i dont know how to put in my frequency channels i got
I couldn't locate a manual for you, but the 16-channel BC145XL is a fairly typical Uniden scanner.
Turn the scanner power ON.
Press the MANUAL button to stop scanning.
Press the MANUAL button repeatedly to advance to the channel that you wish to program.
Enter the frequency that you wish to program, including the decimal point. Frequency range of your scanner is 29-54, 136-174, and 406-512MHz.
Press E (Enter) to cpmlete the process.
To continue programming, press MANUAL to advance to the next channel, and start the steps again.
For a comprehensive database of active frequencies in your area, visit
Dec 09, 2009 | Uniden BC350C Base Scanner
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
How to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
May 31, 2008 | Health & Beauty
Help please
how do i program it
Oct 23, 2007 | Uniden BC244CLT Base Scanner
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
87 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
