I have connected a cannon mx700 all in one with my imac osx computer with a usb cable and am printing successfully. How do I connect the fax. I have comcast triple play: digital cable, hi-speed internet & phone and only one phone line.
  • david c in s Mar 02, 2009
    I have already done that. What's next?
  • 916 Answers
You need a phone line splitter connect it to your phone line then connect one side to the fax machine and the other to the phone. After that check the documentation of the fax machine I would change the distinct ring settings so it can automatically pick up faxes and ignore phone calls.
Posted on Mar 02, 2009
    Scholar:
  • 165 Answers
Connect your phone pin directly to the printer.plug the phone pin into the fax pin outlet of your printer.
    Sergeant:
  • 239 Answers
You can go to radio shack and pick up a phone line splitter so you can have both plugged in at the same time.
hope this helped
please rate well
IMac deactivates USB port when I connect my Nikon P300
Try connecting the camera directly to the computer, without going through a hub. If that doesn't work, then buy a card reader.
Apr 20, 2012 | Nikon Coolpix P300 26246 4.2x Fast F/1.8...
I have an Cannon MX870 All-in-one printer... It is all connected but will not print from my computer. I can copy and fax items but can not print from my computer. Please help.
Have you installed the supplied software in your computer and have you physically connected your printer and your computer with a USB cable, which is sometimes not included in your printer package? And it's a Canon, not Cannon.
Aug 08, 2011 | Canon Office Equipment & Supplies
Mx700 printer will not print documents from my computer
First, insure it will print without a connection to the PC: install/re-install cartridges, then see if it will (automatically or manually) print an alignment page. If not, try another set of inks.
If it will print offline, then plug USB cable to PC, and see if it is installed to the PC. If not, you must install it. If it is recognized and says it is ready, then go to the Printers & Faxes tab on your START menu, find your printer and RIGHT-CLICK on it. Open the Properties tab and see the driver, then tell it to print a Test Page . If it does not, you mmay have the wrong driver installed.. If that is the case, you can go to www.canonusa.com, and click on downloads then put in your MX700 model to find the correct driver. Download the driver and tell it to run and follow the prompts to install. When finished, try another test page as stated above.
Apr 23, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a i mack and a canon mx700 cant get it to print
hello, please ensure that all of your apple software is up-to-date on your imac and that you have installed all of the canon software for mac. in your utilities you will have an add printer option and the your canon model should be listed there , select it and you should then be able to print.
Oct 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon FS100 Digital Video Camcorder. I am attempting to download some video on to my iMac, but then I select "Connect To Camera" I get the message "No Camera Was Found". I have the camera plugged...
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
Hope these helps and have a great day!
Aug 12, 2009 | Canon FS100 Flash Media Camcorder
No scan with imac
Make sure that the hardware is functioning correctly.
Restart the product and the computer
Manually check the USB connection between the product and the computer
Make sure that the USB cable is connected correctly to the product
Test the USB connections and restart the computer
The USB cable is connected to a USB hub or a docking station for a laptop
or Desktop.
Fully uninstall and reinstall the HP software
Use the MSCONFIG utility to enable the Startup software
Try the scan again
If the scan is successful, the issue is resolved.
Aug 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Cannot connect to Computer
Turn off computer. Turn ON computer and immediately hold down Apple+option+p+r. after 4 chimes let go. You are going to be using the Firewire cable. once the camera is on and plugged into computer go to : apple> about this mac> more info click on Firewire. on the right hand side you should see your camera. Now if you don't its either the Firewire port on camera or the cable it self. to further isolate. Get your older computer. leave off. plug the firewire cable into both computers. Now the older computer that is turned off. TURN ON and immediately hold down the " T " on keyboard. ON the polder mac, your screen with have like a "Y" icon.. its a Firewire icon. Now look on the other computers desktop, do you see a yellow or blue hard drive on desktop. IF you do.. ITS your camera because we just tested your cable and both ports and they are working. Now try the USB cable and see if its detected by computer by going back to Apple system profiler and see if the computer is detecting it
Mar 24, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
Imac won't connect to netgear WGR164 via VIRGIN CABLE
this router is not compatible with cable and imac so i was told to get a BELKIN "N" WIRELESS ROUTER AND USB ADAPTER  for cable. installation was quick and had my router working in 4 mins. yayyyyyyyy
Dec 06, 2008 | NetGear WGR614 Wireless Router
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
20 people viewed this question
k24674
