Question about Toshiba TP50F50/51 50" Rear Projection Television
Clean the screen on Toshiba TP50F50. How?
I want to clean the screen (inside and out)on my Toshiba TP50F50, but don't know exactly how to remove the screen, and more importantly what to use to clean the screen. It is in a family room that has filled with smoke on several occasions over the years. I think this may be affecting the visual quality. Any useful suggestions would be appreciated. Sarcastic comments can stay away. Thanks.
  • Anonymous Apr 12, 2009
    I want to clean the inside of the screen but am not sure how to get inside?
Only use tap water with baby shampoo.
12oz. add 1/2 teaspoon of baby shampoo. (this is non-abrassive)
Posted on Mar 02, 2009
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50F50 rear projection tv power light blinks on&
did you purchase these because you thought this was part of the problem? if is a convergance problem you should have some picture it would be distorted or color bars would be on the left or right of the screen. if the light is flashing and you have no picture at all or any audio you have a power supply problem. it is not letting the proper voltage energize the main board.
Sep 02, 2008 | Toshiba TP50F50/51 50" Rear Projection...
Toshiba TP50f50
unplug the set for a half hour and start over. As long as you did not save the settings, all should be ok.
Sep 14, 2007 | Toshiba 50H13 50" Rear Projection...
Need instructions on removing the front screen for ceaning spider webbs
THERE IS A BETTER WAY TO DO THIS THEN REMOVING THE SCREEN--IT CAN BE DONE BUT UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING YOU COULD DAMAGE THE SCREEN.
Here is what I would suggest checking out first.
1) With the set unplugged remove the back cover.
2) With the cover off if you can see the three large black lens---and have enough room---get a swiffer type duster on a rod and carefully reach up inside from the back to get all the webs out.
3) If this works---it is also a good idea to wipe the three lens clean of any dust--do not remove the lens--it is not needed--you can clean then with a paper towel with glass clean sprayed on it--they are glass not plastic.
Let me know if you have questions--I am here to help.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Toshiba 65H80 65" Rear Projection...
It has a spider web inside the screen and I need to know how to clean it because it is directly in the center of the screen
The best way to get at it is through removal of the front screen. Start by removing the front speaker grill-should just pull off (snap fitted). Then remove the front control panel (4screws). Next remove 4 screws from bottom of front of screen- the screen should ten just pull off -also snap fit- Make sure the set is unplugged before you begin- Once the screen is off you can also clean the lenses and the mirror (if glass) use a soft damp cloth.
Sep 26, 2009 | Toshiba 50H82 50" Rear Projection...
I want to remove the screen of my 42" Toshiba TheaterWide to clean the bulbs of dust and the inside. How do I remove the screen to get inside?
there are screws behind the speaker cover-remove them-take out screws along back edges-carefully remove screen(its plexiglass) clean all 3 tubes with a soft cloth -be carefull cleaning screen most liquids will stain it-also clean mirror-reassembly unit
Sep 03, 2009 | Toshiba 42H81 42" Rear Projection...
Need to clean inside of toshiba 50a60 model screen. how does screen come off frame?
TAKE THE SPEAKER GRILLE OFF FROM THE FRONT REMOVE 3 SCREWS LIFT UP ON THE SCREEN AND REMOVE IT TO CLEAN
Aug 24, 2009 | Televison & Video
Need to remove screen cover
you have to remove the back of the tv to clean the inside screen.
Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
Convergence Problems/Toshiba TP50F50/51 50 in. Rear.
yes, but make sure you get the parts from a reputable seller.. They do have knock offs as well as chips that didnt pass the full test sold cheap which will work temporarly and then fail again.
Picture goes to static and reappears
sounds like the board has bad soldering connections on it.
Aug 28, 2007 | Toshiba TP50F50/51 50" Rear Projection...
Televison & Video Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
