Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The st arter engages but will not over come the
The starter engages but will not over come the compression to start the engine
I have had the same problem from time to time. I turn the ignition OFF and then manually rotate the engine as far as possible in both directions to free things up a bit. Once the starter gets a "running start" at the compression, it will generally start cranking.
Posted on Mar 11, 2009
  • 49 Answers
Make sure you have a good, charged battery. Clean all the connections on the battery, the starter, and the ground (black) wire on the frame. If it still does not work, the starter my have an internal short. Hope this helps.
Posted on Mar 02, 2009
Lawn mower wont start
clean out carb.
Mar 14, 2015 | Garden
1999 Pontiac Sunfire 5 speed won't start. Replaced spark plugs and checked ignition coil (fine). Sounds like it wants to turn over but makes a "whining" noise. Please assist. Thank you!
Is the engine turning over with the key in the start position? If the engine is not spinning over and you hear a whining noise, the starter is not engaging the flywheel. If the engine is turning over with the starter engaged, the engine has most likely jumped time that creates low or no compression which results in the whining noise.
Mar 03, 2015 | Pontiac Cars & Trucks
What would cause a 2005 vstar classic 1100 not start when the starter is engaged and why would it sound as if the engine lost its compression and how would i go about finding out what the proublem is
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Starter Clutch Star 1100 Wiki Knowledge Base
How To Star Starter Clutch Replacement Sample
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jul 05, 2014 | 2005 Yamaha V Star Classic
No compression
When it "whines" is the engine actually turning over? If not, your starter is not engageing the flywheel and is just spinning. could be some missing teeth on either the starter gear or flywheel.
Oct 27, 2013 | Subaru Cars & Trucks
Starter is turning but engine isn't
The solenoid or pinion gear linkage may sound healthy but may, in fact, have become too weak to engage
Dec 28, 2012 | 2005 Ford Fiesta ST
Bobcat starter stays engaged
Trace the wire from the "st" on the ignition switch to the small post on the starter relay or solinoid. If you find another wire going off from there follow it to the diode. It is likely covered with insulating sleeve at one end of the wiring harness. It is about 3/8" in dia and 3/8 long.Please note the colored band at the end which denotes the cathode.It must be replaced with one going the same way..
Hope this helps, Robert
Aug 16, 2012 | Bobcat Welding Tools
The engine dies if I don't keep the ignition turned forward. Any ideas?
Pull the distributor cap off and watch the rotor as you crank the motor. If the rotor doesn't turn your timing belt is broken. If the Engine is actually firing while you have the starter engaged but dies immediately when you let off even when you press the accelerator check to make sure the starter isn't staying engaged in the flywheel as that will kill the motor and burn your starter out. If all is good so far do a compression check. If you don't have good compression on all cylinders your engine maybe firing but with no compression will not run.
Aug 07, 2010 | 1988 Ford Bronco II
FJ1100 won't turn over when under compression.
Sounds like the starter sprag clutch on the flywheel is slipping.
Jul 29, 2010 | 1984 Yamaha FJ 1100
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
193 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
