Question about Toshiba Satellite 1135-S1553 Notebook
Will not start up
My computer toshiba p200-rt1 laptop has power but will not start up. It shows that it is plugged in.  when pressing the on button i get nothing. please help...
  • 679 Answers
Try removing the battery and replacing it. If that doesn't fix it hold down the power button and it should re boot. If still a problem we can go further.Thanks
Posted on Mar 02, 2009
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
Laptop won't switch on although blue power light on is showing power is getting to the machine
Check the power adaptor led is not flashing. Flashing Adaptor LED indicates fault with laptop charging circuit / powerboard
If it will not boot on battery, and you know the adaptor to be good, the issue lies with the motherboard.
Sometimes, removing the battery, and unplugging, pressing the power button and holding it for 30 secs, replacing the adaptor only will allow it to boot up, but this will only work if the motherboard is not damaged r the CPU fan has not failed.
Jan 27, 2011 | Toshiba Satellite P200-13Z Laptop AC Power...
Computer won't turn on
try removing the battery and then plugging the laptop in. when you plug it in make sure that the light comes on that shows you the laptop is charging. If it doesn't wiggle the power chord inside the laptop till it does light up. Then press and hold the power button. With these Toshiba Ive seen that you may have to press pretty firmly. Hope this helps :)
Dec 27, 2010 | Toshiba Satellite L505-S5966 Notebook
My Toshiba Satellite P200-1ee It just quit charging and the light doesn't show being plugged in, I've replaced the battery and charger but still nothing
Sounds like your power connector may need to be replaced. This is a common issue with the laptops that I repair.
You already isolated both the battery and the charger, so the item in between the two that may fail, is the power connector.
Good luck
-Carlos:
Jan 21, 2010 | Computers & Internet
Toshiba P200-1ee Screen fault
Hello, I have a Toshiba Satellite P200-rt2 that has the same issue. They told me that there's a part that connects to the monitor that needs to be replaced. It costs as much as the computer does. So, I have bought a new one. I want to know if there are other people with this issue. Maybe we can go to Toshiba with this issue.
Oct 21, 2009 | Toshiba Satellite P200-0TD00Y Notebook
Toshiba laptop won't start
pls replace the ac adapter and charge the battery, after fully charge pls check the power on. if not pls power without battery, also remove the battery and power on , after power off plug the battery,
Sep 28, 2017 | Toshiba ZA2055P08 - Satellite 1800 24X...
My toshiba satellite p200-140 laptop will not start up. the power button lights up but nothing else happens. it was working fine last night
My laptop had a similar problem. I left my laptop running and some time later when I went back to my laptop, it would not startup. The power light seemed to be on but the laptop would not function. I tried several things like pressing on the power key for some time without any success and also tried all sorts of alternate buttons and sequences.
I resolved the problem by first disconnecting the power cord then by removing the battery for 5 minutes. I then re-installed the battery then connected the power adapter.
As soon as I turned the power button 'ON', the laptop booted up again.
Hope this works out for you.
Regards,
Rick
Sep 28, 2008 | Computers & Internet
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite 1135-S1553 Notebook Logo
207 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
