Question about Akai LCT2715 27 in. LCD Television
Samsung le32r88bd sound but no picture. eneyone have any idea what the problem is .
My landrover 3.5 v8 keeps cutting out and making popping sound
Yes I have an idea get the thing to a shop and have the electronics scanned for fault codes.
Apr 10, 2012 | Land Rover Defender Cars & Trucks
I am struggling to connect my sons PS3 to my Samsung LE32R88BD. I am using a HDMI cable but keep getting no signal
Hold the power button for for 15-20 seconds. The ps3 will cycle through all the video modes until it finds a correct connection. It should automatically change its settings to HDMI and you should get video.
Oct 10, 2011 | Sony Playstation 3 (PS3) Console
My lcd tv samsung le32r88bd has a small black shadow on the screen, just over 2 years old can it be repaired and if so is it expensive. cheers
The panel is bad. Yes it is expensive to replace. I would contact mfc to see if they will help. Be firm but not nasty.
Dec 05, 2009 | Televison & Video
Av main digital board problem
contact andrews electronics in california
Mar 06, 2009 | Televison & Video
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
Aug 21, 2008 | Samsung HC-P4241W 42" Rear Projection...
Archos problem
hmmm...nice assortment..and would you please restate the problem here, or link back to original issue?
May 26, 2008 | Archos 605 WiFi Digital Media Player
My new Samsung LE32R88BD was showing a pixellated picture on movement, but it filled the entire screen. Since switching my Virgin box through HDMI, the picture is less pixellated but I cant get the picture...
I did some reading on the net, try to "calibrate the screen". Try set the input to 1080i, then run the thx optimiser to give you a starting point, then try a bluray with a bright image.
Keep replaying the same chapter and try raising and lowering different settings. you may find that your brightness is set way too high and after dropping it from 90 to 29, you may find that detail will have crept into the image. Try giving the colours a boost as well.
The detail in HD is very subtle, and having a properly calibrated screen will make all the difference. So to answer your question: set your input to 1080i, make sure your HDMI is outputing RGB and start tweaking that screen!
Mar 08, 2008 | Televison & Video
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Akai LCT2715 27 in. LCD Television Logo
194 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
