My screen (LG flatron W2052v) shows the message: "Check signal cable" when starting the comuter and I cannot do anything...
  • 916 Answers
Check to make sure that the monitor is connected correctly to the computer. If it is the problem is the graphics card and it will need tyo be replaced.
Posted on Mar 02, 2009
  • 13,433 Answers
Seems like there is no signal from the computer check that its starting up and working test with antoher monitor.
  • Ekse Mar 02, 2009
    I suspect that the screen is actually perfectly fine. The problem is most likely the computer not starting up properly or the video card not giving signal, you can easily test this with another monitor, almost any monitor. if you get picture with another monitor then the problem is indeed with your current monitor but test it again with the monitor and see if the problem is gone.
    If you don't get any picture with any screen. Then your computer is not starting up.
    If your computer is covered by warranty I would suggest instead to contact your dealer for warranty repair service. if your are outside of warranty you can safely open the case and disconnect all ram modules. (ofcourse unplug all cables)
    with no ram in the computer plug in the power and try starting up, it shouldn't and it should beep.
    turn it off and unplug again
    Then you could plug back in the other ram module and try starting up. again
    let me know if you have picture at this point, and if you want to continue you could accept my solution so we can communicate better.
When i on my pc then the lg screen show me message analog power saving mode and then screen turns black. how can i overcome this problem
I would say that it doesn't see any signal coming from the computer. Check your output. Check the video drivers. Try another video display.
Aug 10, 2011 | LG Flatron L1951S-SN 19" LCD Flat Panel...
17" LG crt having display problem it looks same if we decrese the brightness ,fully dark we can't see anything on the screen
You can check the VGA Cable (the cable which connects the Monitor to Cabinet) try pushing the cable to the Cabinet.
Check the same monitor to different system if
Problem could be internal hardware - show it to computer technician
Jun 03, 2010 | LG Flatron F700P 17" CRT Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Jan 15, 2009 | LG Flatron 776FM 17" CRT Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
Problem
hmm,
Exact message could Find a Closest solution.
anyways, what you might be getting is a message like,
No Input signal,Check Video Cable.
it means that the Connection from the Monitor to PC is Loose,
Connect them Secure and tight to FIx it.
Jul 16, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
