Question about Mitsubishi Diamond Plus 100E Monitor
Mitsubishi diamond pro says "no signal"?
Help, i got a diamond pro monitor which gives me the No Signal message.
The monitor does power up, so its not the power supply.
when i plug a computer into the vga connector, i dont get the signal, just the same box floating around saying no signal. Also if i press the menu button in the front of the monitor, i get no response to it.
any advice, help, tips & tricks are most welcome.
thanks
  • 3 more comments
  • j.oed Mar 02, 2009
    yes, i have tried it on 2 different machines, both machines work fine with other monitors.
    About the cable you speak of, is it inside the chassis ? i have not opened her up (yet). Although now after your reply, you give me new hope :) thx, i will try to check this in the next days.
    Also if you can outline a few more possibilities for me to try out, will help a lot since the monitor is at a friends & in one go i can go to her & try a whole lot of things.
    So, in this situation if the cable/connector is connected internally & seems fine, what could be the next fault ?
    Most appreciate your feedback, looking forward to more :)
    Thanks & regards.
    its the mitsubishi diamond pro 2040u
    thanks for all your suggestions rob, i will check them in the next days & let you know the feedback & results.
    you have been a great help already, thanks again, i really would like to get this baby working again.
    cheers
  • j.oed Mar 05, 2009
    hi Rob, well, now i have bought the box over to my place, opened up the main plastic chassis & took out a few of the metal plates inside, so far all seems well & i dont see any blown out looking parts, i still have to take out a few more boards though, so i will keep you updated on this.
    Now, about the status of the monitor, when i power on with a working source computer connected, the light comes on green & the osd displays "No
    Signal", then in a few seconds the light turns amber & displays "Power Save".
    There are about 4 different boards in the machine, which should i try to examine to pinpoint this problem?
    Yes, there is a black cable from the vga board going upto the Video PCB & it seems fine. I dont really see any bloated capacitors or burnt resistors etc (as of now, like i said i do need to open up more), I look forward to your assistance with this.
    Much appreciation for your time & guidance.
    sincere regards
    ps. is there a way i can send you photos of the boards, so that you may better analyze & tell me if something looks amiss? let me know, thanks.
    wow .thats amazing, i was reading through the other posts on the fixya & well this seems to be a very common situation with many different monitors & is probably something i will be able to fix without intensely expensive costs, nice to know :)
    i will start to diagnose the problem in the next days, in this time if there is anyone out there with a clear picture of what to do with this particular model of monitor (Mitsubishi Diamond Pro 2040u), i would very much appreciate the support, thanks in advance.
    cheers
  • 463 Answers
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Posted on Mar 02, 2009
  • Rob
    Rob Mar 02, 2009
    Yes, the cable is inside the chassis. It runs from the sub=15 vga connector affixed to the back of the unit (it may be wired straight though, though, depending on the model of mistsubishi) to a pcb in the back.
    Other thing to check is the power supply board... just look and see if anything looks unhappy like an overly fat capacitor or a resitor or diode that looks smoked.
    Best of luck,
    Rob
SOURCE:
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
I want download driver for Mitsubishi Diamond Pro87TXM monitor.
After a google search i found these drivers, http://www.nodevice.com/driver/company/Mitsubishi/page2.html
Hope it helps
Steven Cumming
Please leave positive feedback :-)
Jun 05, 2011 | Mitsubishi Diamond Pro 87TXM 17" CRT...
My monitor is switching off in an unexpected manner and I suppose that there is a defect with the main power supply switch
First thing please check powercode is proper attached or not with monitor and power supply side
second thing is that due to bad power cable that its happen so please change power cable
May 20, 2010 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Mitsubishi NEC Diamond PRO 930SB Monitor - cover removal?
Remove the screws as you have done. Looking at the monitor front on you'll see 3 bits sticking down from the top (in the deatil gap) which are clips unclip them by pushing through the corresponding holes along the top. Also there's a clip at each side on the underside of the monitor which are very obvious. With the monitor facing down and everything unclipped just pull the cover upwards. It's not easy but work your way round the front edge and it will come.
Jun 26, 2009 | NEC Mitsubishi Diamond Pro 930SB 19" CRT...
Monitor Does Not turn On...
My Friend you have a problem in the power supply, you try voltage check, check if you have output in the b+. if nothing, there is a regulator in power section, for example ic401, you look at the board you will see all the components section of ic401, all the capacitor have 4 for example c423 or resistor r423 like that one. You check all the section of the power supply. Hope I help you. bye
Mar 20, 2009 | Apple Mitsubishi Diamond Pro 2060u 22" CRT...
No signal after standby/power interrupt
check in BIOS to see how wake up is set
Also right click desktop go to properties/settings/advanced check setting for wake up
Jul 22, 2008 | Diamond Multimedia Stealth S60 RADEON...
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Now the monitor flickers..
Your monitor is slowly dying. Get ready for the eventuality and start saving some bucks for replacement.
Sep 18, 2017 | Mitsubishi Diamond Pro 91TXM 21" CRT...
Mitsubishi Diamond Plus 100E Monitor Logo
152 people viewed this question
Top Mitsubishi Computers & Internet Experts
Alun Cox
Argospete
Argospete
john h
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
