Question about Cougar Cycling
The brakes on my wifes bike don't stop her quick enough. How do you make the brakes tighter so when she pulls the handle the bike will stop.
  • 50 Answers
You un-do the cable for the brake and move the breaks closer to the wheel.
http://www.ehow.com/how_14159_adjust-bike-brakes.html
Posted on Mar 03, 2009
I was not able to get brake adjustment on the recumbent foldaway bike. I attempted adjustment using the nuts on the cable ends but was unsuccessful in achieving any additional brake. Please advise
You probably need to loosen the nut that attaches the cable to the brake arm, pull it tighter and then retighten. The cable may also need to be lubricated inside the housing with spray lube. Other than that, without being there it's hard to help further. Check with a bike co-op or bike shop for more assistance.
Feb 14, 2018 | Cycling
How to adjust disc brakes on a mountain bike
Most disc brakes are the same as other brakes. The cable comes down to the brake. When you pull on the cable, the shoes tighten on the disc. To adjust, loosen the bolt on the end of the cable, with a pair of pliers pull the cable tighter, re tighten the bolt.
Aug 31, 2014 | Diamondback Cycling
Quick release bike tire installation
the pads don't need to be removed. Most brakes have a "quick release" on them. On linear pull brakes, use one hand to squeeze the two lever against the rim and with your other hand you can pull the "L" shaped cable noodle out the bracket and this releases the brakes. (you can also let the air out of the tire and install the wheel then reinflate the tire once you have it back on the bike). On road bikes with side-pull brakes most have a small lever you can flip up that activates a cam mechanism that opens the brakes up to allow the tire to pass through. Canti-lever brakes are similar to linear-pull brakes, just squeeze the brakes together and release the straddle cable. Hope this helps.
Aug 13, 2014 | Cycling
Squeaking front brakes on daughters bike. V brakes with a power adjuster
They are not adjusted right, front of brake shoe should touch the wheel rim first. If , you do not know how to do it or don't have the tools, go to your dealer or to who assembled your bike. It is important to have the brakes working properly, not worth trying to cut corners and pay to have it done right. She has to be able to stop quickly.
Apr 13, 2011 | Cycling
Chain keeps falling off
flip bike upside down losen back tire and pull it away from the frame (the chain will visualy get tighter) hold wheel in disired place while tightening up the nuts (side note: make sure the wheel isn't sitting crooked so that it doesnt rub on the frame or the brakes) also brake pads are ajustable to go forward and back
Apr 01, 2011 | Del Sol Shoreliner 3i
Brakes will not lock in parking position
There are adjusters on the brake cables that are designed to solve this problem. The cables for the brakes run inside a flexible housing. When you squeeze the handle, the cable should engage the brake. The problem is that the cables inside the housing stretch over time and do not work as well. There is a threaded adjuster at the handle where the housing of the cable goes into the handle. If you turn this adjuster counterclockwise it will, in effect, make the housing longer and the brake cable tighter (shorter). This should engage the brakes better. It make take some trial and error, turning the threaded adjusters clockwise and counter-clockwise to get the proper setting for your strength and comfort. This same adjustment technique applies when you pull the handles down in the park position and when you squeeze them to slow down. Hope this helps.
Nov 22, 2010 | Drive Medical Winnie Walker, Mimi Lite...
I am thinking of getting a Suzuki S50. I
My wife rides an C50, they are a little different with the C50 having a lower center of gravity and a biggere bike feel but still only a little over 400 lbs. But al we do is normal maintaince to the bike and it is very trouble free! She has riden from Wichita to Glacier Park and back with no trouble and at highway speeds... Again I will say my wife rides the C50 I ride a Vulcan 2000
Jul 15, 2009 | 2007 Suzuki Boulevard
Wheels lock when self propel not engaged
Hi
a;; you need tp do is loosen the cable slightly to the self drive mechanism
Apr 05, 2009 | Garden
Cycling Logo
107 people viewed this question
Top Cougar Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cougar Cycling Expert? Answer questions, earn points and help others
