Question about Whirlpool GEW9250 Electric Dryer
There is no heat in the dryer when working.who do I get to fix th
Who do I get to fix this we are on the NOrth Shore Auckland
  • Anonymous Mar 08, 2009
    WHIRLPOOL ELECTRIC DRYER, DUET MODEL HAS NOT HEAT. IS IT THE THERMISTOR OR WHAT COULD IT BE. THANK YOU, KIM
  • kjcemc Mar 08, 2009
    I have the same problem. Have you identified what the solution is yet.
    Kevin
  • 686 Answers
Heating elements are bad
Posted on Mar 12, 2009
Property boundaries for 105 shore st north cleveland
You are going to have to hire a surveyor. Not even tax records show a property boundary
Jan 24, 2018 | North Office Equipment & Supplies
The rotating brushes on my floor setting keep stopping on carpet - even though nothing is clogging it. I have to turn my vacuum off and then back on to get it to start spinning again.
There are two things that cause this.
1) The suction is not good and is not making the turbine head run. Clean the filters/ head and check the hose for blockages
2) The Turbo head has more friction than it should. Remove the brushes from the turbo head and remove all hair etc from the bearings with tweezers.
If it still does not work the the most common problem is the bearing retainer in the turbo head has heated up and come loose. This is a very hard repair I do but for most they should buy a new turbo-head.
Keith from Dyson Repairs North Shore Auckland
Sep 24, 2014 | Dyson DC29 Animal Vacuum
Dyson DC07, is it possible to clean inside the circular sleeve (the one with holes) that is accessible when the shroud is removed to facilitate emptying,
I remove the complete cyclone/bin and hose it down with high hose pressure in all holes until you see no more dirt. Do not do this to the vacuum cleaner! Then dry it for a couple of days making sure it is completely dry before use. This gets rid of pet odour. Replace the post motor filter if this needs doing as it will be blocked.
Sep 24, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Where is Grouse Mountain?
Grouse Mountain is one of the North Shore Mountains of the Pacific Ranges in the District Municipality of North Vancouver, British Columbia, Canada.
Jul 04, 2014 | Computers & Internet
Dyson stopped working
There are three things that "stop" (no noise anymore) a DC07 working. I will list them in order of the most common to least common faults.
1) The motor is burnt out. Caused by over filling and not cleaning the filter regularly. You must replace the post motor filter when getting the motor replaced
2) The power cord has failed. This can usually be seen by visually inspecting the cord for damage.
3) The on/off switch has failed.
All of these faults should be repaired by a licensed sparky for safety reasons.
Keith @ Dyson Repairs North Shore Auckland
Jun 22, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
SPRING URETHANE BLACK 12.7MM ID X 25.0MM OD X 38.1MM TH , DUROMETER ; SHORE 95A, B-116-064 for my jazzy 1107 Power Chair are cracked and busted causing my rear wheel caster assembly to lean backwards in...
I know that 95 durometer EVA is available from other sources like shoe findings suppliers. This is about 1/2" by 1" by 1.5" and if a mechanic was able, he could fix you up with that. If that is what you need, they could help you out without having to replace the whole assembly.
Feb 28, 2017 | Health & Beauty
My dryer will not heat up it is going through th motions but with cold air
Hello feeona sounds like the heating element is bad if its new it should be under warranty but if its old you need to go check on one at a store near you that deals with that equipment sometimesit cost more to fix old appliances than to buy new one sometimes not though
Nov 06, 2008 | Dryers
Sears kenmore dryer 11064602300
Check the power input. perhaps one of the hot legs is not working. When I say this I mean that the dryer is plugged into a 240V receptacle (if you live in North America). This means that each of the hot slots are 120V. The heating element uses both of these for a total of 240V, but the controls use only one for 120V. The element may seem to be working, but it could be only half-voltage.
Or it could be a faulty timer circuit.
Sep 06, 2008 | Kenmore 62822 Electric Dryer
Krell 250a power amp
Hi There WLAW,
I am in Auckland NZ and do repair work for a high quality Amplifier chain so I could have a look at yours for you....
Being Local in Auckland it will save you sending it away off shore to Australia.
Cheers From YUBEUT (09) 357 7496
Dec 26, 2007 | Krell Home Theater Standard 7.1...
Whirlpool GEW9250 Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
