Question about Hobart Welders IronMan 210 MIG 500304A Welder
Excessive wire speed on hobart ironman 250
Wire speed 0=150"/min,10=162"min,20=192"/min,30=232"/min
Do I need a new reostat?
I have cleaned the contacts on the voltage switch
    Champion:
  • 225 Answers
To find out if you need a new reostat disconnect the wires from it and put an ohm meter on it and check the ohms resistance it should read up and down ohms as you turn the dial.
Posted on Aug 02, 2009
I have a Hobart 140 Handler, My Problem is the feed wire is feeding too fast. It can not be regulated with the speed control. I believe the problem is with the pc board but not a 100 percent sure.
Hi:
In order to check the wire speed control you will need to open the machine and test the wire speed control mechanism (rehostat, potentiometer) with the use a volt meter. If you see a a variation on it while moving the knob then your problem is the PC board.
Good luck and have a great day.
Aug 22, 2011 | Hobart Handler 140 Mig Welder
I have a IRON MAN 250 Mig Welder. that the wire don't feed, with regularty. I have a miller with the same tourch that dose the same thing. If you pull about 4 or 5 inches of wire out, with trigger...
Hi:
If you see rust on the wire then you should stop and change the gun's liner, change the contact tip and clean the feed rolls. Rust can accumulate inside the gun and make the wire feeding a problem.
Aug 21, 2011 | Hobart Welding Tools
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Weld arc not stable. Wire feeds, good ground, everything looks good, liner pulled and cleaned, new tip.
Try moving the tip closer to your work and try turning your wire speed down
Most people want to crank up the wire speed when it spits and sputters
Turn it down
See if this helps
Mar 16, 2010 | Hobart Handler 140 Mig Welder
Hobart 210 makes an arc but the wire feed motor won't turn. used very little ,has voltage at motor,worked fine the last time i used it
hi,
maybe you haven't got the wire speed control turned up probly not the answer but sometimes its the simply things.
Mar 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Wire speed control just turns around and around it is on a lincoln 100
take knob off the restat and turn the reostat if it still goes round n round reostat is shot.
Feb 14, 2010 | Lincoln K2528 1 Flux Core Kit For Power...
I have a hobart ironman 210 that lost all power but no circuit breakers blew switch is working but no power output to cooling fan or gun
take side panel off where power goes into unit,check for voltage ,if not go to where plug is plugged into check for power if there is power check the crows foot to make sure all three wires are tightly screwed to terminals
Feb 02, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Feb 28, 2009 | Hobart Welding Tools
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Hobart Welders  IronMan 210 MIG 500304A Welder Logo
111 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
