Question about HP Laserjet M1319F Laser Multifunction Printer
No dial tone on fax machine
I can't get the fax to work as I don't get a dial tone. I have a Roger's land line and was wondering if this is the problem.
    Genius:
  • 2,120 Answers
Yes, all fax machines are analog.
Posted on Mar 03, 2009
Fax machine shows no dialing tone. what must I do to rectify?
check phone line is connected to fax machine
check phone line works with a phone plugged into the phone line you are using
Oct 19, 2016 | Office Equipment & Supplies
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
No dial tone
Very strange that there a no other symtoms.
Are you sure you are plugged into the LINE port of the fax machine?
Oct 18, 2008 | Brother IntelliFAX-2440c Plain Paper...
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
HP Laserjet M1319F Laser Multifunction Printer Logo
297 people viewed this question
Seeker5211
Seeker5211
