Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Flat tire, sitting on the rim
My ( it belongs to the small condo association I am part of) Yard Machine/26" 8.0 HP Tecumseh
has a flat tire and needs a tune up.
I wonder if there is a service that either will come to my house to repair it or to pick it up and take it somewhere to be repaired.
If I were able to get it into some truck, where would I take it?
Names of services? Types of places that would do this?
I'm near Boston, MA
4 Suggested Answers
SOURCE: Mounting Tubeless tire on Rim of riding lawn mower
With the mower jacked up place a belt or rope around the center of the tire all away around and draw it tight. Apply pressure and when the tire starts to fill you can release the belt. Apply pressure until you hear the bead pop, indicating that it has a bead lock to the rim. Let the air out to the right pressure, check all tire pressures and set the deck to level. Go mow your lawn.
Posted on Aug 23, 2009
SOURCE: lawn mower stops after a few miniutes
this could be the spark plug, a clogged fuel filter or mabey it has a gelled carbarator
Posted on Aug 31, 2009
  • 3074 Answers
SOURCE: How do I take off Front Tire of Power Built 500cc
http://www.ehow.com/how_7479789_change-tire-troybilt-riding-lawnmower.html
Posted on Mar 13, 2011
Yard machine snow blower wont move wheels locked up model 31as6fee729
check for rusted shafts and or bearings as you use this machine a few times a year in the worst possible conditions and the rest of the time it sits idle in the shed.
Jan 29, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Flat tire
i find the when they are stuck that bad you will break more by trying i pop of the beads with a pry bar and just change the tires right on the machine keep in mind if the outside has rust the wheel where the tire seals will as well if so put in a tube it will save you time later
Jun 18, 2012 | Yard Machines MTD Gold 23 HP Garden...
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Removing a flat tire from a yard machine snowblower? Not sure how to get the rim and ther tire off together. No manual to work from. Try to turn the head oif the bolt but the wheels move not allowing me to...
The Rims get froze in place after a while. You can try spraying some WD40 it and let it set for some time but I suspect you will need some Heat and a Hammer. I had to Heat up the axle area and strike it from behind with a good size Hammer to get mine off. A Puller won't work because there isn't anywhere to grab the rim. WD40, Heat and a hammer!!
Dec 15, 2017 | Sport & Outdoor - Others
Runs fine on flat ground will not pull a hill
Sounds like you could be running on one cylinder. I assume you have a two cylinder B&S, Tecumseh, or Kawasaki. Remove one spark plug at a time and try driving the mower. If you have nothing on one spark plug and drives exactly the same with the other, then you have a dead cylinder. Can be a spark problem, unlikely a fuel problem assuming a single carb, a bad head gasket, bent push rods. A lot of B&S Vanguard engines, including mine, have a tendency towards bent push rods.
Oct 18, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 30'' mower front tire off rim can't put back on
hello...is the tire loose but still on the rim...the sidewalls no longer engage the rim tight to hold air but still aroung the rim loose....If that's the case, get a jack, can of fix a flat, and a small ratcheting hold down strap.....jact the tire off the ground.....wrap the strap around the tire and ratchet it tight to get the beads of the tire to touch the rim....then commect the fix a flat or, if you have ,,,air from compressor to inflate the tire,,,,might have to work it a little to get the tire to reseat on the rim....this should work for you....once the tire is seated on the rim....stop inflating the tire until you remove the strap or you migh have a problem getting it to release from the tire if fully inflated....
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard machine rototiller has a flat tire.
You may have to bring it in to a tire mounting service station, as these small tires can be hard to re-seat. You need enough air pressure to seat the tire bead in the rim.
May 06, 2009 | Mtd Products Yard Machines 158CC Tiller
I would like to change the front tires lawn mower
Remove the wheel from the mower.
Let all the air out
Lay the tire flat
Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
Apply soapy water to the tire and rim
Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
go
Repeat the last step for the other side of the tire, same side of the rim though!
Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
Mar 22, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
79 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
