Question about E-Machines eMachines Monitor E15T4
The brightness and color have dimmed.
My LCD monitor went crazy. The brightness and color have dimmed. Almost a green hue. Every one in a while it will come back on, but not for long.
  • 78 Answers
This could be something with the cable or an internal connection if it is intermittent.
Posted on Mar 02, 2009
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
My monitor display color is low
If it is dim, try upping the brightness from the on-monitor menu. If the colors are wrong, check the connection at the back of the monitor and the back of the computer. It could also be that the LCD is dying, which happens from time to time.
Dec 11, 2012 | Computers & Internet
Light on monitor turned to blue
Sorry man! You have defective monitor. Consult the workshop
Jun 04, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Screen very dim ..how do i turn up the contrast /brightness
Hello !
Test with an external monitor. If it works, there is a problem with the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
May 08, 2010 | Computers & Internet
Monitor just went dim.
The blinking power button indicates a short in the power supply which is then not putting out the full voltage needed to give a bright display. This is a very common problem with LCD monitors after 2-3 years of service. It is caused by heat buildup in the case causing parts called capacitors to blown out causing the power supply to short out which in turn make the power light just blink. You can repair it yourself if you can solder. We have a repair diagram posted on our web site at: www.ccl-la.com Replace the parts shown and you will be back up and running. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. Let us know if you have any other questions about the unit or the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 23, 2009 | Gateway FPD1975W 19" LCD Monitor
My NC-10 screen just went crazy. I can tap on the
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | Samsung Computers & Internet
Laptop colors on monitor not right-red is pinkish, blue is teal
take it back to the customer service for the LCD to be changed
May 20, 2009 | Panasonic Toughbook 28 Notebook
Brightness of monitor changes itself to quite dim
YOu can go to the monitor settings to make sure nothing's been changed. It could be an energy saver issue where the display dims after a certain period of time, and you can reset it to longer period of time so it would stay bright for you
Dec 12, 2008 | CTX PV 700B 17" LCD Monitor
Monitor gone dull
there is a key on the keyboard which controls brightness. on mine it is the second key on the right, of the bottom row. it has a small sun on it. Press this key at the same time as the function key (on mine, bottom row, second from the left, blue key marked Fn) - and the monitor will brighten up.
Apr 19, 2008 | Computers & Internet
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
E-Machines eMachines Monitor E15T4 Logo
115 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
