Question about Amana PTC153B35AE Air Conditioner
I NEED A SCHMEMATIC
AMANA PTC153B50AE
    Guru:
  • 462 Answers
I may have on is some older amana lidterature. But will need the MFG number to look it up.
Posted on Mar 03, 2009
Wiring schmematic for a 1500cc kawasaki vulcan
I would go directly off an ignition switched source capable of dealing with the current draw. OR I would use a sealed 30 amp minimum relay using the ignition switched lead to trip the relay and run a fused feed from the battery to the relay to power the lighter. That way you do not pull a lot of current from wires that may not be able to handle it. seal everything watertight or bad things will happen....
Aug 12, 2014 | 2001 kawasaki VN 1500 Vulcan Classic...
I need a manual for an Amana Glass Top range 5yrs old , self-cleaning, large oven
You need the model number of the range to get the correct manual. Most Amana manuals are available here: http://www.amana.com/content.jsp?pageName=CustServ . The model number is on the frame of the range behind the storage drawer. Often you need a flashlight and fairly good vision to read off the characters on the plaque.
If you add a comment with the model number, I'll check for the direct link to the manual.
I hope this helps.
Oct 21, 2011 | Amana Kitchen Ranges
I have an Amana model ptc153b50ae Air/Heating unit. It has stopped blowing heat and does not turn off. I have to unplug it from wall. What could be the problem?
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 19, 2011 | Heating & Cooling
I need to get an on-line manual/problem w/hoses thru window
www.managemylife.com/mmh/owner_manuals/17647/AMANA-Air-Conditioner-Room-(42)-L0523054
Jun 01, 2010 | Amana AP095R Portable Air Conditioner
The assembly that holds the drawers in the refrigerator has broken. I need replacements.
You can buy them from Amana directly. Go to their website
http://www.amana.com/ and loacte your service / spares centre
The parts list diagrams can be found at the following Amana Support link
http://shop.amana.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10242314.pdf
Oct 21, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
I have a 4 burner amana grill and need to replece
bbq parts .com appliancefactoryparts.com
Aug 09, 2009 | Amana 5939 Grill
Amana PTC153B35AE Air Conditioner Logo
120 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
