I changed starter relay and the black box thats hook to it but still wont start looked for a defrost thing in freezer it dont have one what else ?I changed starter relay and the black box thats hook to it but still wont start looked for a defrost thing in freezer it dont have one what else ?
TIS THE TEMP CONTROL if it gets smacked it comes on going try cleaning it with wd 40TIS THE TEMP CONTROL if it gets smacked it comes on going try cleaning it with wd 40
You can't post conmments that contain an email address.
Check battery connections and cables. Ground may be broken. Remove cables and clean battery posts then reconnect cables. Check ignition switch, replace as needed.
I ran into the problem and it was corrosion on the battery terminals. on the inside against the battery. also check the the terminals for good connection.
Stay warm
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
1. Turn on your wipers and pop your hood.
2. If you hear you wiper motor, then you do not need to check your fuses.
3. If your wiper arms are moving freely, then your linkage from the wiper arms to the motor is disconnected and possibly broken.
4. If the problem is electrical, do the following:
1. Check the fuse, and check for power at the fuse.
2. Check the wiper motor for ground. For a complete circuit, you need power going in and ground coming out. Check electrical connections for corrosion or poor connections.
3. Get a wiring schematic and trace power to the wiper motor starting at the fuse box in the following order:
Fuse box
wiper switch
wiper motor
4. In the rarest of cases a wiper motor or wiper switch is at fault. I do not recommend replacing anything unless you have proof that the part is faulty. (ie. power going into the switch but nothing coming out.)
Light turns on, but does not get cold. And the motor is making a buzzing sound.
RB172PW MODEL
