Question about Kenmore 24032\24036 Top Load Washer
The agitator works intermittently
I have a Kenmore top load washer. .The agitator works intermittently. It agitates for a moment then stops and makes a ratcheting sound it will then start agitating again and work a few seconds before it stops. It does this continuously while in the wash cycle.
I took the agitator apart and there is a small nylon ratchet part that looks OK, but I suspect that it is worn out. Any suggestions to what might cause the agitator to work sporadically
  • 188 Answers
Replace the agitator dogs (4 small white/beige plastic parts) inside the agitator, they are worn.
The part number is 80040.
Posted on Mar 02, 2009
Washer makes clicking sound while agitating
you should replace the control panel or get a new washer.
Mar 01, 2014 | Whirlpool Washing Machines
I have a Lady Kenmore Ultra Fabric Care Heavy Duty 90 series top load washer that is about 20-25 years old and works very well. I think that an object has slid under the big thing in the middle of the...
if it is like the other you have to remove the top cover of the agitator cap with a small flat head screwdriver, then using a 7/16" socket and ratchet with an extension remove the bolt(right hand thread) and pull up the agitator.
good luck to you.
Feb 08, 2011 | Kenmore Washing Machines
I have a Kenmore Series 80 washer that agitates a little but is very weak. Spins Ok. Clothes don't clean very well. I need help.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Feb 23, 2009 | Kenmore 80754 Top Load Stacked Washer /...
My washing machine spins but will not agitate
Turn the agitator (auger) by hand. It should work like a ratchet (turns one way, locks the other way). If it spins both ways, you need to replace the agitator dogs (funny name, I didn't make it up).
This can be done by removing the top cover off the agitator and removing the bolt that holds the agitator to the drive shaft. Then remove the top section, flip it over and replace the dogs (small white plastic pieces). Reassemble in reverse manner.
If the agitator dogs are ok, you may need a gearcase (transmission).
Feb 19, 2009 | Kenmore 24032\24036 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator and spin cycle
if you hold onto the top of the agitator stopping it from turning, and turn the "blades" at the bottom, does it make a ratcheting, clicky sound when you turn them opposite direction from each other
Oct 06, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator problems
sounds as if the transmission agitator pawl is slipping. inside the transmission is a gear connected to the agitator. there is a spring loaded pawl that rotates around the center and engages its pawl or hook into the agitator gear for each rotation. either the pawl hook is worn or the agitator gear is rounded off. the transmission must be opened up to see what is a miss
Aug 22, 2007 | Kenmore 22422 Top Load Washer
Agitator
Faultly agitator spline or gear box fault. Regards Advisor
Kenmore 24032\24036 Top Load Washer Logo
274 people viewed this question
Sal De
fordexpert
Robert Rankin
