Question about Dell Studio 1737 Laptop
I am trying to add a printer to my new Dell laptop with Vista. The printer is on a workgroup computer in another room. I've gone through all the "normal" steps, but the laptop cannot communicate with the computer in the other room although the internet signal comes through. Any suggestions?
  • 1 more comment
  • Zarko Ristevski May 11, 2010
    What Operating system is on the another computer ?
    What IP addresses are on both computers, Automatic or Manual ?
    If there are manual addresses, please check if the addresses are in same range (e.g., and same Subnet Mask.
    Are they connected on the same Router/Switch ?
    If the second PC (with printer connected on it) is different from the first one with Vista (e.g. Windows XP), did you install 'additional' drivers ?
  • tleeski
    tleeski May 11, 2010
    Are both computers set up for file and print sharing? Are both set up on the same workgroup? There will be no communication between the computers if not.
  • Kurtis Stalnaker
    Kurtis Stalnaker May 11, 2010
    Is the printer a network computer or USB?
I have a wireless laptop running Win7 home. My husband has an older desktop running XP, my son has a custom PC running XP. I have done everything I can to try & get the laptop to print to our HP 5
This might be a simple case of the three machines each having a different "network" or "workgruop" assigned to it.
In Right-click Computer, Properties, check to see what workgroup these machines belong tol If they are all different, then simply change them to match each other, so they all use the same resources, and the same printers.You will then have to re-add the printers, having first dleted the printer, if it was on the wrong workgroup.
But, once they are all on the same workgroup,and compatibility has been restured, you whould have no trouble getting them to use the same printer.
Jul 16, 2012 | ASUS Computers & Internet
How to I set up my dell laptop in my house to print wirelessly from a canon mp780 printer?
Basicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.
Mar 25, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Help! Our Dell Inspiron 1521 laptop (service tag# 28D58F1) stopped printing. It was printing through our wireless network to our main computer with printer attached with no problems and then one day we...
There are several things to look for, but here are the first things to check:
  1. Is the printer plugged in and turned on?
  2. Can you print a test page from the main computer to the printer? If not, check what is in the queue to print on the main computer. Delete (Cancel) any print jobs in there that are not printing.
  3. Is the printer on the main computer marked as shared, if not, mark the printer as shared.
  4. Look at the print queue on the Inspiron laptop, if there are jobs stuck in there, delete (cancel) any stuck print jobs from the laptop and attempt to print a test page from it's printer properties by right-clicking on its icon in the control panel and clicking Print Test Page.
  5. If none of the above has revealed the problem...
    1. Remove the printer from the laptop by right clicking on its icon and choosing to remove the printer.
    2. Click on Add Printer and attempt to add the printer back to the laptop by following the instructions that come up. If the printer is not located, make sure your wireless network is running and that you are able to connect wirelessly with both the main computer and the laptop.
      1. Make sure that you are on the same Workgroup or HomeGroup
        (right click on Computer (or My Computer, or This PC) in your file explorer and choose properties to see your Workgroup or Homegroup information) in any case, both computers must be on the same network).
Oct 18, 2017 | Dell Computers & Internet
I have a iomega eGo 500GB which I used on a dell laptop running Windows XP. I backed up all my files on the drive and now have a new laptop running Vista (old laptop has gone) put whan I pluged in the...
Enable "File and Print Sharing" on the "old" computer.
Connect the IOMEGA to the "old" computer.
Enable file-sharing on the "root" folder of the IOMEGA.
Connect the "old" computer to one of the LAN ports on a router (wired or wireless).
Connect the "new" computer to another LAN port on the same router.
Make sure that both computers are in the same "workgroup".
From the "new" computer, browse to "show computers in my workgroup".
You should see an icon for the "old" computer.
Double-click that icon to "open" that icon, and you should see all the files on the IOMEGA.
Copy those files to the 'C:' drive on the new computer.
Nov 11, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
Sharing Canon Pixma ip3000 photo printer with Vista from XP
On Vista machine, Go to Control Panel. Choose printer. Then choose Add Printer.
Choose Add a local printer. Click on Create a new port. The default in the drop down box is Local Port. Do not change that. Click Next.
A dialogue box will appear asking for you to enter a port name. Type in the \\computer name\printer name
Dec 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
Laptop accesses network, but not desktop
you need tocheck the sharing, on both pc's go to taskbar on right, right click the network icon, click network and sharing centre and ensure the sharing buttons are all on.
Make sure thay are also on the same workgroup, right click my computer icon>properties>advanced system settings>click computer name tab and check the workgroup name is the same eg both mshome or workgroup
Sep 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
I am trying to share a printer.
Are they both under the same network? Can the pc find the laptop under network connections and vice versa? If not, then right-click my computer, go to properties, go to the tab 'Computer Name' click on the button change, and make it part of a workgroup of your choice of name. Do this for both making them part of the SAME workgroup.
Then, make your printer shared under that workgroup.
Mar 30, 2008 | Linksys Wireless-G Broadband Router
HP 3100 LaserJet All-in-one Print Driver for Vista OS
It doesn't work in share mode either...It prints the pages incorrectly. I have the hp3100 connected to my xp pc and my vista laptop connects to it via printer sharing on my network. the xp prints fine but the vista doesn't print ok due to lack of driver support for it.
I have to resort to print to pdf and then take the pdf to my xp for printing. Its a half *** solution but if anybody out there made his/her own driver please post.
Jan 25, 2008 | HP LaserJet 3100 All-In-One Printer
Dell Studio 1737 Laptop Logo
77 people viewed this question
Alun Cox
