Question about Cameras
Is a new M2gb xD card compatable with a Olympus C5050?
I've been running a 1gb mini-drive in my C5050, but decided to purchase a M2gb xD card to gain more capacity. The card works on my reader and is formatted for FAT, but it is not reconized in the camera. The screen on my camera wants to format, but then does not see the card when I say yes. Have I exceeded the abilities of this camera to read and use a card of this size?
  • 2 more comments
  • diverigor Mar 03, 2009
    In regards to your offered "solution", I cannot understand why an Olympus reader can read the card fine and the camera cannot see the card at all. It just does not make any sense. I can try another card, but that will entail mailing this card back and waiting for another taking several weeks in the process. Are there any other "solutions"?
    Still looking for a reasonable answer.
  • diverigor Mar 04, 2009
    I've done that. FAT is what the camera uses and I do not own a MAC. Any other suggestions or ideas?
    I guess that is what it boils down to. Does the camera support the 2 gig chip or not? Does anyone know this definitively?
  • 423 Answers
Yes I know that it will not support a card of this size. Also, the latest firmware upgrade does nothing to help that either. Sorry, It's not what you wanted to hear, but better the truth right?
Rob
Posted on Mar 04, 2009
  • 4,472 Answers
You will definitely have issues trying to use the bigger cards on this device based on when it was made. I would just go with having multiple 1gb cards. If you still need further assistance let me know. Please take a moment to rate my solution accordingly.
Thank you,
Lee
    President:
  • 1,901 Answers
Yes, that's what it boils down to. Your camera does not support that size card.
Here is your manual: C-5050 Zoom Manual
Check out pages 25 and 225 for specs.
Sorry it's not better news.
  • 408 Answers
Memory : xD-Picture Card (16 – 128MB) SmartMedia (4MB, 8MB, 16MB, 32MB, 64MB, 128MB) *1 Compact Flash, Microdrive *2 *1 2MB and 5V SmartMedia cannot be used. *2 340MB Microdrive cannot be used.
Those are supported by your camera.  Anything higher than that is not guaranteed to be compatible.  If the card works on your card reader but not in your camera, the problem is not a bad memory card.  The problem is that the camera can not format the card because its capacity is higher than what the camera can support.  Please be aware that I have seen Olympus cameras that can only use the Olympus brand memory or memory that says Olympus on it.  The specs above were taken from the Olympus website.  As I said before, those cards are guaranteed compatable.  Bigger size ones may work, but are not tested by Olympus, so they can not guarantedd compatability.
Posted on Mar 03, 2009
  • Cameras Master
  • 19,396 Answers
The Olimpus Reader can read card that have a format that is not compatible with the camera.
That is because the card reader is just an interface to access the card, using the card reader who really reads the card is the computer operative system.
For example if you format a card using NTFS, then Windows will still read it using the olimpus card reader, but the camera wont recognise it.
Try formatting the card inside the camera, that should work.
If after formatting from camera menu the camera still does not read the card, then test the camera with a different SD card, a defective card can still be read on the card reader but not on camera.
If the camera has problem with different SD cards, and not only this one, then only in that case you call Olimpus, otherwise the problem is the card or the card formatting.
  • Ginko
    Ginko Mar 04, 2009
    Many sellers say that the camera works with 2GB, many users, and also the manufacturer say that this camera does not support 2GB.
    Conclusion: The sellers are wrong, and the camera cannot accept two GB memory card.
  • 916 Answers
The card you are using is not supported by the particular camera you have from what you are saying. Which would be why Olympus could find it but the camera could not. Make sure that the card has FAT support and if you go to get another to try make sure it is compatible both with FAT and your particular brand of camera.
    Master:
  • 404 Answers
I would just format the card using a pc (not a mac). in the camera's manual see what format it reads, fat or ntsf ect..and use that format.
  • lotfi bouakaz
    lotfi bouakaz Mar 04, 2009
    no doesnt support 2Gigs, 1 GIG max
    Scholar:
  • 150 Answers
The camera should have no issues reading a 2 gigabyte card, but in my experience, using adapter devices such as SD readers and such to force the camera to read a different drive is really a hit-and-miss operation. It could just be that you need to buy another of the same type of card for the camera to be able to read it. Try bringing the xD card back for a refund, and using the money to buy another of the same type of card that came with the camera. A 2 gig version of the same card should work just fine.
Please rate, and thank you for visiting Fixya.
Posted on Mar 02, 2009
  • 13,433 Answers
Compair it to the other card is the other card formatted as Fat?
if yes then most likely its not supported by the camera. try a diffrent brand of card in the shop if they let you
  • Ekse Mar 02, 2009
    this camera supports Supports various removable media: SmartMedia,xd-picture card, CompactFlash type I or II, and 512MB/1GB IBM Microdrives.
    this is what I got from the user manual
    128MB)
    *1
    *2
    I'm not completely sure but it would seem 1GB is max supported if 2GB cards don't work then thats it.
    Thanks,
    Ekse
I have a olympus fe-220 using a memory card xd M2gb. i went and bought a new card but its not exactly the same its a xd M+2gb. will i still be able to use the new 1 ? whats the difference between the...
Yes, you can use the XD M+2GB card in your camera. The M+ card is a faster one. The following website gives you more on it.
http://www.olympusamerica.com/cpg_section/cpg_xd.asp
"The Type M+ xD-Picture card is compatible with the Type M card in all cameras and is 1.5 times faster than the Type M card. The increase in speed may be useful in sequential shooting of digital stills and in the recording of high-density video with Olympus cameras."
Good luck.
Jan 08, 2011 | Olympus FE-220 Digital Camera
Can I buy a memory card for my camera?
yes. search for these types: *OLYMPUS D-435 Olympus xD-Picture Card / xD Card 1GB (Type M)
OLYMPUS D-435 Olympus 2GB xD-Picture Card / xD Card (Type M)
these are the compatible storage cards for your camera.
Sep 07, 2010 | Olympus Camedia D-435 Digital Camera
My new memory card will not work for the Olympus Camedia D-560
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Apr 04, 2009 | Olympus Camedia C-350 Digital Camera
Olympus xD-Picture Card "Card Error"
First things first - need to make sure that the card is making proper electrical contact with the camera. Have a look at the contacts at the edge of the card and make sure they are spotlessly clean - even a fingerprint may cause problems.
Also, make sure the contacts in the camera have nothing causing a contact problem, and see if this resolves the issue.
Regards, Andy
Jan 04, 2009 | Olympus Camedia C-740 Ultra Zoom Digital...
Is xd-picture card m-xd1gmp compatible with olympus camedie camera c-350 zoom?
The largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible.
Nov 06, 2008 | Olympus Cameras
Card error when i put new xd card into my camedia c-450 zoom it wont format, comes up with card error message (using olympus 1gb xd card.)
Jul 17, 2008 | Olympus Cameras
XD 1GB card
i think it's just 'cos of the sheer size of the memory it has to access. mine works quite quickly but when i put in a 512 it takes a lot longer i would not say there is anything wrong - just teh limitations of a device which was designed when even 128MB was a luxury ricardi, shropshire
Nov 16, 2006 | Olympus MJU 400 Digital Camera
Memory card compatibility
Can't be much help on this one I'm afraid. I too have a C5050 and have numerous cards the largest of which is 512MB. I wouldn't like to use anything bigger than this just in case the card fails. I don't like having all my eggs in one basket. I quite often change cards on a shoot well before they are full also for the same reason. . Not so expensive to replace as well when they do go wrong. I also have an XD card loaded at the same time and swap between the two frequently That said to date I haven't had a CF or XD card fail on me as yet, but theres always a first time. I've also never had any problems with the C5050 recognising any CF cards of any type up to 512MB in size and cannot see any reason why they would fail to use a 1GB or above.
Sep 12, 2005 | Olympus Camedia C-5050 Zoom Digital Camera
XD Picture Memory Cards
What is the advantage of a 1 gig over two 512meg cards: Usually the 1 gig will be priced lower than 2 512 cards. The 1 gig card will hold twice as many photos. That is about it. .................... Brand name has turned out to be a non-issue for almost all memory cards. They have to be made to a standard and they will all work. Olympus and Fujifilm came up with the xD card. And Sandisk is a trusted card maker. I believe that Olympus may have a stitch feature that is only available if you use the Olympus brand of card. A gimmick to sell more of their brand of cards. This is pretty much of a non issue too, as there are plenty of software programs that can do stitching for panorama photos.
Sep 06, 2005 | Olympus C-7000 Zoom Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
