Question about HP Deskjet F340 All-In-One Printer
Hp F 4140 Prints from computer just fine, copies fine, but will not scan images to computer, I have tried eveything, uninstall install unistall, kick across room, beat with hammer etc..
Click Start Search, or go to control panel, anyway search for camera and scanner wizard, that should work...
Posted on Mar 25, 2009
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Copy function
Try uninstalling in control panel or hp unistaller which ever is recomended in the literature and reinstaling from
the cdrom
Dec 02, 2007 | HP 1010 Plain Paper Inkjet Fax
1410 does nothing when i scan
Check for copying, if its fine no problem with the printer, check system side..If copy also blank replace scan head..pl revert us for further advises
Jan 01, 2012 | HP PSC 1410 All-In-One InkJet Printer
My all in one printer/scanner is not scanning. prints and copies fine, but does not scan
Form your issue that you are able to print and copy but unable to scan it is very clear that it is a software issue. Copy and scan fuctions work this way.
Copy - completely related to hardware.
Scan - related to software
uninstall and reinstall the full version software from Hp for the operation system of your computer.
Aug 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP Photosmart C4240 won't scan any more
I have a hp C4240. It suddenly quit scanning to hp Image zone. It
still prints and copies but I get several different error reports. I've uninstalled abd reinstalled the printer and also did the same with
the computer.......no luck.
Aug 11, 2009 | Office Equipment & Supplies
HP 2410 prints & copies fine but won't scan.
Well if you are able to copy from your printer,it suggests that the hardware is perfectly fine.Its just an issue with the software.May be you are using an old software that is not compatible with the new operating system of your computer.If this is not the problem then try uninstalling and then reinstalling the software.And mind that when to uninstall the software do it completely from the registry,program files as well as add/remove programs.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
My scanner will not "save as" or "scan to". It is an HP 5400c. It gives me an error message and then shuts the program down for me to restart it again. The print function works. I uninstalled another
ok try this and if does not work, call HP and they should send you a replacement. ONLY TRY MY SOLUTION if you have the software to reinstall your scanner.
Go to my computer right click and go to properties, go to hardware, device manager, and find your scanner in the list should be under imaging devices. Click on it once you find it and click unistall. Let it unistall
REBOOT and reinstall with the software. And then try it.
You can also have it install it by going back to device manager right click on your computer name and scan for hardware changes
May 25, 2009 | HP Scanjet 5400c Flatbed Scanner
C3180 will not scan
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
And if the software is not installed the you will have to install the Printer driver / Softaware Sucessfully first.
Good Luck
Oct 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
117 people viewed this question
Seeker5211
Seeker5211
