When I load HP Solution Center, the color quality changes from 32 bit to 8 bit and the icons are inverted. do you know how to correct this problem?
  • 837 Answers
I need to know your video card information and/or your computer make/model and what operating system you are using ...
Posted on Mar 02, 2009
  • 13,433 Answers
Something is definitely not right on your computer, completely uninstall and remove the program and install it again, if that doesn't help try reinstalling your windows to the computer
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
HP J4680- change copy settings so printouts are fast draft
Change settings and copy from HP Solution Center
  1. Open HP Solution Center.
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: Click the Start icon (c01319360.gif ), click All Programs , point to HP , and then click HP Solution Center .
  2. Click Make Copies . The Copy window opens.
  3. In the Paper section, click A4 on the Size drop-down list.
  4. In the Start Copy section, click Black or Color .
  5. In the new window you can also change the copy settings
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Using HP C4280, when I load HP Solution Center, the icons are inverted and the color quality is reduced from 32 bitrs to 8 bit. I have reloaded the oprinter software numerous times, but the...
I would suggest that you check for a video driver update for your video card.
This is a video issue .. what make/model is your computer/video card?
Mar 02, 2009 | Office Equipment & Supplies
Toshiba laptop dvd will not work
Click on the Control Panel, then Display, then Settings Tab. Change the Color quality to 32 bits.
If you cannot change the setting to 32 bits then you most likely have not installed the correct video card driver.
To get the correct driver, go to the Toshiba WEB site, then to the support/download page and download the correct version Windows driver for your model laptop and then install it on your laptop.
You will then be able to change the screen resolution and bit color.
Jan 10, 2009 | Computers & Internet
My Ati 4870
go to start>>control panel>.display.
select setting, maek sur eyou have the correct display listed, change the color quality to 32 bit.
click on advance, change the DPi setting to 96.
Jan 06, 2009 | ATI Computers & Internet
COLOR QUALITY
click on start, then click control panel, find the icon that says display and click on it, when it opens find the tab that is for settings and click on it, there you will find your color setting options, click 32 bit,, then click apply and that should do it. you may have to reboot. good luck
May 15, 2008 | LG Studioworks 563N 15" CRT Monitor
Color quality
this is normal function of the programs some programs do not reset your resolution so you may have to do it manually. candy land did this repeatedly in my daughters computer.
Feb 13, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
13 people viewed this question
k24674
jasbo
jasbo
