Question about Troy Bilt 5.5hp Self Propelled Mower
10hp snow blower won't throw snow
Troy built model, augar seems to work; is this a belt problem?
3 Suggested Answers
  • 89 Answers
SOURCE: how do i essemble a pull starter on a troy built
to just put the rope in take starter cover off look inside the cover and turn thr pully to the left counter clock wise turn till it turns no more line up the two hole one from the pully and one on the starter cover where the rope was originaly put the rope in thr hole and tie a knot this is called preload has to have tention on thr pully to pull the string back but if thr spring is broke its another process
Frazier
Posted on Nov 02, 2009
flores136959
  • 215 Answers
SOURCE: Wheels have locked up on
spray some WD 40 on them let it sit on them for a little wile then try.
Posted on Mar 01, 2011
Mtd model 31a140000. Why doesn't throw snow like it was?
Do you rev it up when you use it? they are made to rev up. Are the paddles that throws snow worn? Even if the skid plate is worn but the snow is getting to the paddles it should throw snow. In saying that no snow blower will throw good if you do not have much snow. The more the better it should throw. They won't work well if there is under 3 to 4 inches. and really throw well.
Jan 19, 2016 | Garden
I have a troy bilt 10hp 26" snow blower and my problem is I keep blowing light bulbs . I've looked at the wiring diagram and would like to know where you find the Dioder/Rectifier at? Please help.
The rectifier should be on the engine either on the recoil housing or just beneath it. You should be able to follow the wiring back from the lighting system to get you close to it. Be safe and good luck!
Feb 05, 2015 | Garden
How can I get my snow blower to idle in a steady fashion?
Tune up and carb adjustment. There are two screws on your carb which control the low end(idle) and the high end (throwing power) Play with those with very small turns to adjust.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Will a 42 inch troy built 2 stage snow blower fit a 2013 troy built poney
howdie what are ya changein ?the blower the motor need more lmfo please or measure the parts line them up look at them you Deside what it looks like I can,t see it so tell me more thks for your time
Oct 06, 2014 | Garden
Troy built snow blower wont blow snow
check youre belts and control cables
Jan 21, 2014 | Troy-Bilt Garden
I have an Ariens 624 series snow blower and every time I use the snowblower the snow spits out of the chute. How do I get the snow to BLOW out of the chute far? I've tried tightening the cord for the...
Looks to me like your second stage is not working. If the auger is turning fine, look and see if the secondary thrower is turning. Probably a shear bold on one or the other is broken. Easy fix, but do not put your hands in there when the machine is running!
Jan 09, 2010 | Garden
Troy Built Snow blower won't start.
Cleaned out caruretor and blew out presumed dirt via compressed air. Thanks for your support.
Jun 20, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Troy Bilt 5.5hp Self Propelled Mower Logo
221 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
