Question about D-Link (DIR-130) Router
VPN tunnel between two DLINK VPN DIR-130
I have a Verizon Fios router (mi42wr) and a DLINK DIR-130 VPN router. I'm trying to configure these two devices together and establish a VPN ipsec tunnel to another office that has a similar setup. It seems that the configuration that Verizon and DLink gave me does not allow me to establish this link. The other office is using Timewarner and DLink DIR-130 VPN router with no problem.
Thanks
  • vernon_bryan Mar 09, 2009
    Unfortunately under Firewall Rules, there is no option to enable or disable Gateway features. The only thing under this tab is Enable DMZ Host, which is unchecked.
    Thanks for trying.
    Vernon
  • Anonymous Mar 14, 2014
    How can I flesh a Dlink DIR 655 Router
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Posted on Mar 08, 2009
Can not access 192.168.0.50
That number is not the router IP. address. Use the tracert command in dos to see what the path is through the router.
Dec 25, 2015 | D-Link Dlink - dir-130 - Dir-130 Broadband...
When I try connecting to my router (Verizon FIOS UltraLine Series3 Model 9100 EM) with the Dlink DWA-130 it says "connecting and key wait" I tried resetting my router and reinstalling the driver and...
I'm having this same problem. Will it connect to any other network? I've tried going into the settings on the network and changing the channel and a bunch of other settings. I've tried 2 different revisions of this same product. I'm starting to think it must be something in Window's that's interfering with my wireless card. I'll keep you posted if I figure anything out.
Aug 20, 2010 | D-Link DWA-130 Pre-802.11n Wireless...
Vpn site to site
you need to create an IPSec tunnel between the router and windows server 2003 (run secpol.msc). From the dlink router, you need to set the IP address of the VoIP gateway as part of the LAN that is included on the VPN tunnel. Since it is the server 2003 that has a static IP, you need to initiate the connection from the Dlink router.
Jun 23, 2009 | D-Link Express EtherNetwork DI-LB604...
Does it work verizon wireless un175 usb on dir-450?>
yes...you must change the D Link IP address and disable the DHCP server...use the IP add within the range of verizon dhcp server..192.168.1.1 is your verizons IP..to chANGE your di link IP connect to Dlink wired and not connected to any routers...type 192.168.1.1 to access configuration menu and you can change the setting
Apr 06, 2009 | D-Link DIR-450 Router (DIR450)
VPN drops when using a D-Link Dir655 router
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Mar 06, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I keep getting disconnected from my companty's vpn . are there settings i need to configure my verizon fios supplied actiontech router. messaGE is "network connection sssion teminated nc app23711"
- Check the Internet if working properly?
- Access the configuration page of your router and open the firewall settings, uncheck the list below:
Enable PPTP Passthough
Enable L2TP Passthough
Enable IPSec Passthough
- Try to gather some VPN ports to open using the router.
Note: You should have your permission from the connection of VPN to use it.
Mar 04, 2009 | Actiontec (GT704WG) Router
Want to make a network connection between two office 800 meters.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Mar 03, 2009 | D-Link (DIR-130) Router
Avaya VPN phone behind a DIR-655
- Logon to the configuration page of the router
- Select Firewall Settings at the left side
- Uncheck the boxes under Application Gateway Level at the bottom part
- And Click on Save Settings at the top.
Jan 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Hello
try this link http://support.dlink.com/supportfaq/DisplayTemplate.aspx?TemplateId=1443235
May 04, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link (DIR-130) Router Logo
2,064 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
