Question about GE WJSR2070B Top Load Washer
WATER IS COMING FROM BOTTOM OF WASHER DURING DRAINING CYCLES
  • Heather522 May 07, 2009
    Sometime during the time following the end of the spin cycle and the filling of the tub, I am having water flow out of the bottom. I am also noticing that the water level in the tub is too high. I am wondering if it is the water level sensor going bad. After reading the information here http://www.acmehowto.com/howto/appliance... I am guessing that will be what I check first. Because it is not making a noise and appears to be draining sufficiently, I am thinking it's not the water pump. At least, that's my first opinion. I will try to test as the article says and then go forward with whatever I learn.
    Problem Solver:
  • 7 Answers
It could be yuor pump or drain hose.
Posted on May 05, 2009
The washing machine is leaking water and it is coming from underneath the washer during all filling cycles and running cycles why?
Could be several things. Check all the hoses, water pump, water valve also check if water is coming from the bottom of tub could be tub seal. Check that there is not a leak in the outer tub somewhere I had one that had a nail stuck in one of the holes in the inner tub and rubbed a hole in the outer tub. Have fun I hope this helps.
Aug 28, 2011 | Washing Machines
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
Hello. My washer seems to be filling up with too much water. It is draining during the draining cycles but fills up with so much water that it is above the window and starts coming out the soap drawer. ...
Sounds like you water level switch is bad.
Without model # I can't research the part # but if you open the lid there will be a metal plate with a model # xxx.xxxxxx go to www.sears.com and select "parts direct" under the sevice drop down and enter the model # where indicated.
You will get a page with exploded views of the washer and a list of part#s
Jan 08, 2011 | Kenmore Washing Machines
My washer keeps draining water during the fill cycle. It pumps the water out as fast as the water is going into the tub. This only happens on the normal cycle-other cycles work OK.
it could be the programer at fault or,,,there is a small pipe from the bottom of the tub that gos to a censor at the top of the washer its the over fill censor pull off the pipe from the censor at the top and blow down it if there is any yuck in it this should clear it out and it may then work ok
Oct 17, 2010 | Whirlpool Washing Machines
I have a Maytag MAH4000AWW. Machine does not drain all of the water out after spin cycles - so clothes come out soaking wet and a little water is left in bottom of drum. Also the Door Lock light does not...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
May 12, 2009 | GE Nautilus 24" Built-in Dishwasher
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE WJSR2070B Top Load Washer Logo
88 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
