Using HP C4280, when I load HP Solution Center, the icons are inverted and the color quality is reduced from 32 bitrs to 8 bit. I have reloaded the oprinter software numerous times, but the problem persists
  • 837 Answers
I would suggest that you check for a video driver update for your video card.
This is a video issue .. what make/model is your computer/video card?
Posted on Mar 02, 2009
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
How do i get my scanner to work?
well did you go to my computer and put the disk of your printer and install it??
May 23, 2010 | HP PhotoSmart C4280 Laser Printer
I installed a ATI RADEON HD 4850, D/L ALL DRIVERS, BUT MY SCREEN IS ALL WEIRD COLORS AND MY ICONS ARE HUGE!
If you are using windows, right click the desktop and go to settings, verify that the Radeon is showing as the installed device, if it shows the radeon, then increase the irresolution to 1024x768 just to be safe, and make sure color quality is 32 bit.
Jul 20, 2009 | ATI Computers & Internet
COLOR QUALITY
click on start, then click control panel, find the icon that says display and click on it, when it opens find the tab that is for settings and click on it, there you will find your color setting options, click 32 bit,, then click apply and that should do it. you may have to reboot. good luck
May 15, 2008 | LG Studioworks 563N 15" CRT Monitor
Color quality
this is normal function of the programs some programs do not reset your resolution so you may have to do it manually. candy land did this repeatedly in my daughters computer.
Feb 13, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Aten Master View KVME CS1774 Wavy Screen
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Jul 04, 2007 | Altusen Aten MasterView CS1764 4-port KVM...
jasbo
jasbo
