Question about AOC 9GLR 19" CRT Monitor
I am getting a burnt smell coming from the rear of the monitor. The screen flickers and you can hear sparks sometimes. Recently the viewable area has decreased greatly and the adjustments won't rectify this.
  • 6,784 Answers
These are capacitors that are burning. also, the resistors are really going threw major stress. i would remove the CRT monitor from the plug and, rebuild the power board immediately before a fire starts. This is a power board issue at the moment but, it will spread as long as power is still running threw the monitor.
Posted on Mar 02, 2009
Good afternoon. I have an LCD . When I turn it
Sometimes LCD screens can flicker if kept in cold environments. Make sure that it's not too cold in the area of the LCD. Also, make sure the cable to the monitor is connected properly, as a loose cable can also cause the screen to flicker.
Mar 05, 2011 | Samsung Computers & Internet
My monitor screen is blank. it also smell as if something is burning.
something is breaking down , some times repairable,sometimes not depends whats burnt out
Jul 05, 2010 | Dell E773C 17" CRT Monitor
1920x1080 resolution-entire screen not viewable
This also happens to my vga connection to my TV.
I used my tv remote "auto" button to re-size it to fit correctly.
If your monitor/TV does not have the adjustment, you may need to
supply your vga compatible device with your monitor's driver software.
This tells your computer what monitor specifications you have.
Mar 16, 2010 | ViewSonic X Series VX2260wm 21.5"...
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Samsung 226bw visible flickers just after it is turned on
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
I have noticed recently that the screen words flicker.
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Jun 14, 2008 | Acer AL2017 20" LCD Monitor
AOC 9GLR 19" CRT Monitor Logo
157 people viewed this question
Top AOC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
