Question about Pioneer Audio Players & Recorders
No power on a Pioneer A-77X Amplifier
The switched and unswitched outlets work. The on/off switch is good. The four fuses on the power supply board are good. Haven't noticed any burnt componets. None of the front panel lights are on. No audio. Completely dead.
  • chuck_hiller Mar 03, 2009
    I have electronics experience and do have a multimeter.
  • 4,234 Answers
The unit is probably in protect mode. Do you have any electronics repair experience? If so, we may be able to work through this. Let me know and we will try a few things. You will need a multi-meter at a minimum.
Dan
Posted on Mar 03, 2009
Unit shut off. Why doesn't it turn back on?
Unswitched power has nothing to do with the power supply of the receiver. Look for blown fuses or a failed component on the power supply.
Feb 20, 2016 | Denon DRA-545R AM FM Stereo Receiver
I cannot get the unit to switch on, I have changed the fuse, removed all cables
Was the fuse you replaced blown? Has AC outlet on the wall been verified to be working properly? If outlet works, modular type AC power cable found to be properly seated and fuse was "OK" you've had a power supply failure that requires shop service.
Mar 27, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
I have a Pioneer model CT-F2121 want to connect it to my Radio amp. I has two ports at back of Radio which is marked "switched" and "Unswitched" Radio is a Sansui model 210SS multi receiver. I have tried...
The deck if in working condition can be plugged into any AC wall outlet or the two AC outlets on the receiver. This is only for power, The Line outs and line in also have to be plugged into the Tape in and record out on the receiver as well. If the CT-F2121 need repairs that is what needs to be done first. Probably a whole set of belts.
Aug 12, 2013 | Pioneer Audio Players & Recorders
Yamaha dsp a1000 won't power up
Your power suply is defective and needs repair.
Or the power amp is shorted will blow inside fuse power line
distribution.
May 15, 2012 | Yamaha DSP-A1000 5-Channel Amplifier
Denon DRA-435R: First, the "switched" outlet on the received stopped delivering power. Now the receiver does not power on, neither using the front switch, nor the remote. The Unswitched outlet still...
from your description its should be the switch or a loss connection
if it doean not power on now it could be the fuse
if you can open the unit follow the power cord inside you should see a glass fuse look if its burn if its ok its better to take to service
Aug 23, 2010 | Audio Players & Recorders
Pioneer M-980 Amplifier not working
Your power switch is arcing.
Needs to be replaced
Check for any fuse on PC boards and make sure theyre ok
Jan 21, 2010 | Pioneer Audio Players & Recorders
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
Unit wont turn on
.Hi jepenny
The board you are looking at is the standby cct and power switching PCB. It sounds like that is working, so you have probably lost power to the transformer primary or the transformer is open circuit. Check for blown fuses and replace with exact same type and rating.
Be sure to unplug at the wall before touching any internals!!
If you can find no blown fuses, the power transformer may have failed. Good luck, get back to me here is you need any more advice. Thanks for using "FixYa"
regards
Graeme
Feb 17, 2008 | Harman Kardon AVR 25 MKII
Pioneer VSX-804RDS
Its really7 a hard thing to say what the problem could be. It could be the stanby power supply. The power switch the power transformer. with out troubleshooting skills it in your best interest to seek a pro to troubleshoot this for you. You could cause alot more problems by touyching the wrong things if your not carefull. Good Luck
May 09, 2006 | Pioneer A509R Amplifier
615 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
