Does the motor need to be removed to replace the stator on a 1997 honda vt1100c shadow spirit
SOURCE: stator removal honda
There is a tool that is used, it looks like a steering wheel puller or flywheel puller. Loosen the nut, a strap tool is handing to hold the stator still while you loosen the nut. Then using the removal tool, you pull this off. reassemble by tighting the nut. You should be able to get a puller at autozone in the loan a tool program. I hope this helps
SOURCE: I have a 2003 honda shadow spirit vt1100c and it
These bikes are notorious for doing this. You must have a good battery to start these engines. I had a '94 VT1100 Shadow and it did the same thing. I bought a new battery and that solved the problem. Take you battery out and take it to an automotive parts house. They'll usually test the battery for you free of charge. Back when I had my Shadow, the only people that made the battery was Yuasa and it was that Yumacron battery. Expensive but it made the bike start well. Good Luck!
SOURCE: how to remove the gas tank from a honda
Take off the nut at the back of the passenger seat and remove. Take off the two bolts at the back of the driver seat and lift off. Take off the bolt at the back of the tank, pull gas lines off petcock, and lift tank off bike gently pulling to rear of bike.
