Question about Kenmore HE2 Plus Front Load Washer
I keep getting a 5d error code on my machine. What is this?
  • My reply is May 11, 2010
    Does it sometimes stop mid cycle or lock with clothes still in it?
  • Jerry Ranita Aug 20, 2012
    it stops during cycle and locks with clothes in it
    Problem Solver:
  • 5 Answers
This is actually a SD code meaning to many suds. The machine will drain out mid-cycle when you push stop. You can then start the load over without adding any additional soap. Make sure you use the recommended amount of HE soap.
Posted on Mar 04, 2009
ERER CODE 5D?
Whirlpool Duet Sport ht 5D/F21 Error Fix - YouTube
? 5:40
https://www.youtube.com/watch?v=2dV3FLzWPTM
Aug 6, 2013 - Uploaded by Mariela Gonzalez-Aroche
Steps in this video may be used to repair both F21 and 5D error codes. ... which is located on the bottom right corner of thewasher machine.
Nov 01, 2015 | Washing Machines
Cabrio washer 5d error code
chances are the 5d error code you see is actually sd. it is supposed to signal excessive suds in the water but it seems to show at other times as well. but regardless of the code and depending on you mechanical abilities, remove the center cap on top of the agitator, remove the bolt and remove the agitator. some force may be needed to get the agitator off the shaft, keep equal pressure 180 degrees apart and work around the base lifting the agitator, gently rock the agitator as you lift. when it comes off take the screws from the gear hub assy out, probably six screws. when the cap is lifted off you should find a small gear, pull it off the shaft, clean and look at the teeth inside. if worn, get replacement part. put back together and run a rinse and spin cycle or similar to see if it spins . hopefully it will solve your problem.
May 31, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
5d keeps popping up on my washer & the clothes are soaked, its not spinning the water out.
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Washing Machines
My kenmore washer is stopping constantly and has error codes like 5d, rL, F21 and some other codes. We checked everything the manual says to and it all seems fine. What is the problem?
That 5d is a clue. Too much detergent, the wrong detergent, or detergent in wrong dispenser can cause the 5d which is suds overdose. The F-21 is from banging on the touchpad in frustration!
Keypad error! Take the base panel off and find the tech sheet behind it. The tech sheet will give error codes and what to try. I have an HE washer service manual and some repair photos HERE
Jan 12, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load error 5d
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck.
Nov 12, 2008 | Washing Machines
Error code 5d???
sure it's not sud? if so may be oversudsingbe sure you are using an he detergent if you are and suds are and issue try cuting back on detergent
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,823 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
