Question about Logitech Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758)
How do u fix the settings for a speed-link joystick it has no swap option. For GOW
  • d_i_m_a_s_z Mar 04, 2009
    My usb does recognise my joystick. So I don't think that, that's the problem. Does anyone know which xbox 360 joystick emulator
    works with GoW. It won't recognise the dinput8.dll.
    Help please.
    I have every possible solution there is to find.
    But none of them works!
    What is this game microsoft is playing you buy a game and it doesn't work. Forced to by a xbox 360 joystick! I refuse!
    Help please.
    somebody?............
Usb not recognise
Posted on Mar 03, 2009
Joystick troubles
This is changed in the settings of the particular game/app you are using. It's commonly found in start menus, setting or options, under controls, and look, aim, or something similar will say 'inverted' ..change to normal and you should look/aim up when pushing up , down when down, etc.
Nov 14, 2013 | Sony Wireless Controller for PS3
Hi, I have logitech wingman 3d joystick , but it went out of calibration , I mean when I try to turn to right it response normally but when I turn it to left It's not accurate... I know the problem...
In windows, go to your control panel in settings. In there, there should be a link for 'game controllers' or similar. Make sure your joystick is plugged in. When the settings start, you should see the joystick mentioned. Click this and then calibrate it from there.
Don't forget to save before leaving.
Dec 20, 2017 | Logitech WingMan Force 3D Joystick
I have installed and callibrated but still wont work when gaming
go in your game go options key confg set it to joystick and set controls if there is no opt. to change to joystick the game doesnt sapport the joystick
Nov 12, 2009 | Genius MaxFighter F-16U. USB PC Joystick...
I want to know will a Logitech Attack 3 Joystick work on need for speed underground 2 or can you even use joysticks fos racing games
ya the joystick will work you can use it because am also having the same am using it , its perfect but you have change control options in the game to joystick control and also if you want you can the options as you like, but this kind of joy is mainly used for flight running games but it also works for all joypad control games too.
Oct 22, 2009 | Logitech Attack 3 Joystick
Joystick in programming, inhibit and/or charging modeand chair will not run.
This is usually due to either the joystick getting knocked off center or a fault in the control module. If the joystick has suffered a hit such as somebody falling onto it while getting in the chair, or running the joysitck under a table or counter-top(happens often), it knocks the alignment off so that the controller thinks that the joystick is activated, and it will prevent the chair from moving until it is back in its proper location. Examine the joystick for signs that it has suffered a trauma such as the rubber boot being torn, dents on the cover, paint from a collision, etc. Invacare is going to charge you about $1,300.00 for a new joystick, or, you can try sending it to a repair shop. I found one here that I used once and it turned out cheaper...by a lot$. Here's the link.
http://www.flightsystems.com/cart_controls/wheelchair_powered_scooter_market_cart_controls.htm
Keep in mind, it may also be the controller. The only sure way to tell is to swap out the joystick with a known good one, and see if it fires up, if not, then it's the controller. Get your wallet out. I don't know of anywhere to go but to Invacare for the controller. You don't say what kind of wheelchair it is, but if it is one that the controller is built into the joystick then the link above should be able to fix it. If the controller is separate and located in the base, then you have to buy a separate controller from Invacare. To tell, the all-in-one controller will have a very thick chord running from it down into the base; about 3/4" diameter. A separate joystick and controller-in-base will have a smaller chord, about pencil-sized running down into the base fronm the joystick, and will lead to the controller in the base. Good luck.
Oct 07, 2009 | Invacare Health & Beauty
When an incoming call comes in my motorola rokr rings once and then go directly to voicemail even if I press the answer key. What do I need to do to fix this problems?
Possibly it is on aiplane mode, to turn that off
Press menu key
scroll to settings then press the joystick
scroll to airplane mode, then press joystick
scroll right to turn airplane mode on / off
set prompt at startup to turn on or off when you turn the phone on or off here.
Also~
ANSWER OPTIONS:
Press [_] > settings > incall setup > Answer options > multi-key > on or off
Cheers
Apr 29, 2009 | Motorola Mobility ROKR E8 Cellular Phone
God of war
Your ps2 needs to be fixed, gow 1 and 2 are dual layered discs and alot of ps2 originals and slims have trouble playing it, trying calling sony and they can usually fix it for about $45, the laser in your ps2 is worn.  Hope this helps :)
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
Pov speed
Usually you can set the POV scroll speed in the game's options.
Feb 14, 2008 | Logitech Wingman Strike Force 3D Joystick...
Gears of War for Vista and Logitech Rumblepad 2 directional issues (fwd/rev)....
There is a way to fix it: go into your control panel under Game controllers, select your logitech cordless rumblepad 2 and hit
properties -> settings -> Enable Swap Mode -> close -> ok
Now start Gears of War and go into the options menu under controls for the controller.
Invert Axis = yes
Joystick Mode = Left-handed
This fixes the problem with the joysticks, but there is still a button fix that needs to happen. operations for buttons 2&3 are swapped, same thing with buttons 1&4, 5&7 and 6&8. I don't how to fix this problem yet.
Dec 30, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Logitech  Rumblepad 2 Vibration Feedback Gamepad [ 963325-0403 ] (126758) Logo
285 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
