Question about byD sign 4032 40 in. HD-Ready LCD Television
The TV picture stared jumping. Then lines were
The TV picture stared jumping. Then lines were going across the picture. Tried to shut TV with the Direct TV remote and it would not turn off. Control switches on the tv itself do not work. Power - Channel - volume - etc nothing works. Have to pull power cord in order to shut it off.
  • 3 more comments
  • joann213 Mar 02, 2009
    I did shut it off my pulling the power plug overnight then it came on beautiful picture after a few minutes the jumping started again and the controls still did not work.
    TV model is actually D04242M - couldn't find that one on the list
    The name byD:sign is on the front panel and it does say an LCD on the monitor as well as my sales slip. The only other wierd thing is that it has a burn in image down the left edge - which you should not get with an LCD.
  • Rob
    Rob May 11, 2010
    OK, I found the make and model on the internet, and there is no good information out there, other than suspicion this is another "polaroid clone" TV. If so, try unplugging the unit from the wall for about a half hour, and plugging it back in.
  • Rob
    Rob May 11, 2010
    TV make and model?
    Leave TV unplugged for 1/2 hour and plug back in.
  • 463 Answers
If, indeed this is a polaroid clone TV, most probably the fix is a new "control board", at the cost of $400 if TV is not under warranty.
Sorry to not be of more assistance.
Posted on Mar 02, 2009
LINES ACROSS TV AND PICTURE JUMPS UP AND DOWN HOW TO FIX
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 05, 2014 | Televison & Video
My tv worked great then while watching it it stared to get lines through the picture then it just shut off and now when you try to turn it on it just shuts back off within 5 seconds
amiepoole1,
You have a bad main board. It is not currently available on any of the websites I use for parts. You can go to http://www.emcompass.com and put in a research request for the board. If it is available they should be able to get it for you at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 11, 2011 | Daewoo DSJ-5510CRA 55" Rear Projection...
36" RCA Proscan TV no picture
LINE ACROSS THE MIDDLE IS THE VERTICLE CIRCUIT--COULD BE A LOOSE CONNECTION-TRY TO TAP GENTLY ON TOP OF SET AND SEE IF YOU SEE THE PICTURE ACTUALLY JUMP TO FULL RASTER,,IF SO LOOSE CONNECTIONS IN VERTICLE CIRCUIT---THE OTHER PROBLEMS WOULD BE ACTUALLY PARTS BAD IN CIRCUIT --IC,CAPS ETC... TUNICA
Oct 21, 2008 | RCA P52926 52" Rear Projection Television
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
byD sign 4032 40 in. HD-Ready LCD Television Logo
435 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
