Our dishwasher is showing the F error display. We have unscrewed the Aquastop and reconnected, turned tap back on etc but it is still showing an error. Is there a reset button somewhere. Any ideas welcome.
SOURCE: Hello, i have a Siemens
It's possible that the Aqua-Stop flood protection system has been activated. I can probably help you, but I really need more information.
1. When you start a wash program, can you hear the pump running? - This will be a low pitch humming sound.
2. There is a dome/mushroom shaped plastic protrusion in the bottom of the washing compartment, located behind and between the salt compartment cap and the drain. Can you lift this up (be gentle) or is it already up and can only be pushed down?
Please post this information and I will try to assist you further.
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
SOURCE: "my Siemens dishwasher model se54m355eu
Tap symbol indicates a water problem.
Check that the water supply to the dishwasher has been turned on.
Check that the water supply hose hasn't bent or kinked.
Check the water supply first, see what you find.
If you can feel water travelling through the water inlet pipe that means the machine, when first switched on must be doing the following.
Drain pump runs.
Drain pump stops.
Water is heard entering the appliance.
Is this correct?
If not, is the drain pump running continuously while it is taking in water?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
