Question about Toshiba Satellite P205-S7476 Notebook
How do I set numlock to be on at start up?
When I turn on my laptop I have to manualy turn on the numlock to log in. Can I set the numlock to be on at startup?
  • iamairdoc Mar 02, 2009
    I already tryed the bios. The option to chang the numlock stting isn't in the bios on this machine.
    Scholar:
  • 56 Answers
Almost every computer does this in the BIOS
To access the BIOS Setup on your system, the system must be off, and not in sleep/suspend or hibernate mode. Press the power button and then immediately press and hold down the F2 key. When the POST (Power On Self Test) finishes, the BIOS Setup screen will appear.
I believe you have the Phoneix BIOS. Use the arrow keys to navigate and to the desired option, the one Concerning Numlock and Disable it. There are different ways to do this, but flipping through the options is usually done with the + / - or PgUp / PgDn keys.
When you get the value you want, navigate to the exit menu and make sure you save the changes you made. You should be good to go.
Posted on Mar 02, 2009
  • Toshiba Master
  • 4,806 Answers
Hi there
you need to restart the PC and enter the bios, this is usually F2 on start-up, have a look through the bios and set the numlock to on at start-up.
Good luck and thanks for using Fixya!!!
  • Lee Hodgson
    Lee Hodgson Mar 02, 2009
    Hi again
    If there is no option in the system bios then you are stuck with having to do this manually as there is no option to set the numlock from within Windows. If you want to check on this yourself go into the control panel, click on keyboard and/or regional options and you will see for yourself.
    Kind regards
Changing the BIOS for NumLock to be ON at reboot
some bios settings have this setting some dont just go to your bios settings and look for numlock boot and enable it
Mar 24, 2014 | Dell Inspiron 15 3521 15.6" Laptop...
Tip
Turn off NumLock
Numlock is on but I can not find it on my keyboard, if you are facing this problem here is what you can do
  1. Go to Start
  2. Then All Program
  3. Accessories
  4. Accessibilities / Ease of Access ( Depending on what type of Windows)
  5. On- Screen- Keyboard
  6. When in this look for Numlock and press it, it will turn off now
on Oct 27, 2010 | Computers & Internet
Tip
Annoyed that your Num Lock key isn't on when you start your PC?
Here's a quick tip to ensure your numlock key stays "ON" by default when the computer starts.
1. log off your PC to the Ctrl-Alt-Del screen
2. Turn on the NumLock key
3. Hit Ctrl-Alt-Del (like you are about to log on)
4. Don't log on, hit the "shut down" button to turn off your PC
This saves the numlock key in the "ON" position by default when the PC starts.
on May 20, 2010 | Computers & Internet
My numbers keypad is not working
Step 1:
Laptop or Desktop ?
ENABLE NUMLOCK KEYS USING REGITRY Check the LED light that indicates whether or not the Number Lock is enabled. If the light is on, press the "Num Lock" key on your keyboard. Look for the light to turn off, signaling that the Number Lock has been disabled. Change your Number Lock status at start up (Number Lock is disabled on start-up by default). Click "Start," then "Run" and type "regedit" to pull up the Windows Registry. Open the "HKEY_CURRENT_USER\" folder, then subsequently open the "Control Panel\" and "Keyboard\" folders. Double-click on "InitialKeyboardIndicators" and change its Data Value to "1," to disable Number Lock on start-up. A value of "2" would turn the Number Lock on after you log in, while a "0" value would result in it turning off after you log in.
CHANGE THE DEFAULT NUMLOCK KEY b> Go to the Start menu. From the Start menu choose "Run." Type in "regedit." Hit "OK" to open the regedit application. This allows you to change your computer's default settings. Navigate to the keyboard's default settings. Using the navigation bar at the left, choose "HKey_Users" then "Default" then "Control Panel" and finally "Keyboard." Look at the right side of the window. On the right are the various default options you can change for your keyboard. Double click on "InitialKeyboardIndicators" to change the NumLock default. A window will pop up. Change the NumLock default by entering a 0 or 2 in the "Value Data" field. Enter a 0 to have the NumLock set to off by default. To set the NumLock to on by default, enter 2. Hit the "OK" button to save your changes. Restart you computer. Your NumLock default changes will not take effect until your computer has been restarted.
Feb 13, 2013 | Computers & Internet
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
Numlock problem in HP DV9000
why need to press numlock when it has already a numeric numbers above? when pressing numlock on a laptop it will turn the letters to number because you lock the it. now to go back on the letters you have to press again the numlock key.
Apr 07, 2010 | Computers & Internet
When i press a key with a letter and a number the n4mber appear. i have to press fn for the letterns to work
press Fn+ numlock key for some laptop its F8. that will disable the number lock. thanks
Mar 28, 2010 | Lenovo ThinkPad T61 Notebook
When i typed my password it dosent enter to the setup.
his causes the customers to have troubles logging into Windows if they wont notice the numlock status.
Here's what you need to do.
1. Start the system up
2. When on the logon screen, turn the numlock OFF(FN+numlock). Do not login yet, instead restart the computer via the power button.
*The numlock should be off by the next reboot.
Mar 03, 2010 | Acer Aspire 5520-5908 Notebook
Want numlock on as default at start up
There is an option in the BIOS setup to turn the NUMLOCK ON when the computer boots. If you know how to get to the BIOS, it should be easy to find on one of the menus.
If you do not know how to get into the BIOS, watch when the computer first begins booting. It should say something like, "For Setup Press <Whatever Key>". You only have a few seconds to press the stated key. Once in, search for the option for NUMLOCK. When you are done look for "Save and Exit".
Oct 18, 2008 | Dell 0Y3740 Keyboard
Driver for PAUK10 keypad with Mac OS 10.2
Hold down the NumLock key for 4 seconds or more and then it should work.
Also try holding down the NumLock key before you connect it.
Nov 25, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Toshiba Satellite P205-S7476 Notebook Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
