Question about Kensington 72219 Mouse
Wireless mouse - computer does not notice new hardware
When i plug in it does not even notice it is there... it works on coworkers computer but mine is the acer....
  • tfarbent Mar 05, 2009
    the driver is not reading anything. apparently that is a common problem for the acer. none of the normal fixes workded
  • 1,602 Answers
THERE SHOULD BE A PUST BUTTON ON THE MOUSE AND THE USB DEVICE, PUSH BOTH OF THEM AT THE SAME TIME UNTIL THE COMPUTER TELLS YOU THAT IT FOUND A NEW DEVICE AND REBOOT COMPUTER AND REBOOT
GO INTO CONTROL PANEL OPEN DEVICE MANAGER GO TO MOUSE AND UPDATE SOFTWARE, YES
CLOSE EVERYTHING SHOULD WORK FINE.
RODGANDYSR
Posted on Mar 05, 2009
Logitech mouse causes scroll function to stop working on my computer
A different driver or replace wireless mouse hardware
May 14, 2017 | Logitech Cordless Mouse
We have been given a computer that came with the phillips freevents mouse and keyboard, we have plugged in the usb and it flashes three times and does nothing we have tried to connect the mouse and the...
How to install wireless Keyboard and Mouse?Along with the development of the computer world, various brands of wireless keyboard and mice sets appear, you can purchase them from website or regular computer stores as well. Whatever your case may be, the directions for getting them ready for your computer are all basically the same. So, if you've bought a wireless set recently and you're having some trouble getting it to work, just follow these instructions and you'll be well on your way to wireless bliss!
First of all, wireless keyboards and mice aren't able to receive power from your computer like the wired ones do. Therefore, they need batteries to operate. And that's the first thing you need to do. Turn your keyboard over and you'll see a battery compartment. Take the cover off and insert the batteries according to the + - (plus, minus) compatibility. When you're done with the keyboard, you can go ahead and do the same thing for the mouse.
Once you've got the batteries in place, find a spot on your desk where you'd like to place both the keyboard and mouse. You won't have to move them around anymore, so make sure you find a place you'll be comfortable with. Now, while you're doing this, you'll also want to keep in mind where the wireless receiver will go. If you recall, a tip on that was in yesterday's newsletter.
The next thing you'll want to do is install the software that came along with your keyboard and mouse. Now, keep in mind that if you have Windows XP on your computer, you more than likely won't need to deal with the software at all. You can just plug the receiver into your computer and XP will automatically recognize the new hardware for you. On the other hand, if you're using an older version of Windows, you will need to install the software. To do so, just insert the disk into your CD ROM drive and follow along with the on-screen instructions. That's all you have to do!
The next step is connecting the wireless receiver to your computer, but again, if you have Windows XP, you've probably already done this. If not, it's likely that the wireless keyboard and mouse set you have works via a USB cable. So, all you have to do is find an open USB port on your computer and plug the receiver in. Once you plug it in, your computer will configure the keyboard and mouse so you can start to use them. You'll see a message that says something like "Your new hardware is now ready to use." (In XP, you'll get a pop up message that says "New Hardware Found"). Either way, that means you can now start using your new hardware!
Now that you've got everything set up, the next thing you'll want to do is test the keyboard and mouse, just to make sure everything's working properly. Go ahead and open some programs with your mouse and type some text in with your keyboard. Run through all the keys on your keyboard to make sure there are no problems with any of them and make sure all the buttons on your mouse work right.
Now, go on and enjoy your new wireless keyboard and mouse. Wireless really is the best way to go!
Apr 19, 2012 | Computers & Internet
Wireless mouse does not work after changing batteries.it always has in the past The Dell computer and mouse is probably 8 years old but has always worked.
Try moving the mouse receivers usb plug in to another port. Unplug any new devices and restart computer. Then replug in any new usb devices.
If still not working.......
Look at Office Depot and other office stores for a replacement wireless mouse. I have seen them as low a $9.99 on up. You might even want to upgrade and get a wireless mouse and keyboard set.
Mar 08, 2010 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
My wireless mouse is not working
Hello sbregar here, your problem is not very hard try ALL usb connections, if that doesnt work go to HARDWARE under control panel and click new hardware, you go through a wizard and it should work thanks. :D
Feb 14, 2010 | Microsoft Wireless Notebook Optical Mouse...
My wireless optical mouse is no longer working
You replaced the batteries. Okay. Did you install drivers for the mouse from a CD? Are you using Windows XP? Do you notice any change if you use the mouse on a darker surface as opposed to lighter surface? If the computer installed the drivers for you, then you might want to delete them in Device Manager (might be called something like HID-Compliant Mice. Single click on that entry, press the delete key. You might have to reboot your PC after that. From there you might have to unplug, then plug in the mouse again and you should notice the driver reinstalling. Give it a second and all should be good.
*Access the Device Manager by right-clicking on My Computer, select Properties, go to the Hardware tab and select Device Manager.
Mar 20, 2009 | Computers & Internet
Keyboard not working
To connect the keyboard or mouse to the computer, you must connect the wireless device through the USB port and get it to hold a good connection. You do not have to install any devices to use these products, they automatically work when you plug them in. When it says that the device is recognized, you are ready to use it! If you have a desktop, you can also plug the wireless device to the mouse port. The keyboard and mouse work properly up to 5' away from the connected wireless device. If you can get the wireless device to work properly, you should have no troubles with the product.
Dec 29, 2008 | Innovations kb985w RF Wireless Keyboard
Wireless optical mouse tracking
Hi, This means you need to buy a new mouse they are not expensive today shop around on the internet. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 31, 2017 | Kensington Wireless Optical Mouse - Red
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
(not) connecting a new mouse
Hello, With the computer off plug in the mouse. I'm assuming it is wired, not wireless. Boot the computer. It should recognize new hardware and work, if not go to control panel and click on add new hardware and follow the instructions. Mouse could possibly be bad. Hope this helps. Thanks
Feb 24, 2008 | Computers & Internet
Mikomi wireless keyboard
Don't run the setup program. Instead reboot your computer and use the windows add hardware wizard to install the drivers from the CD. The windows hardware wizard will detect several different devices, allow it to install them all from the CD.
Dec 01, 2007 | Gateway 2520915 Keyboard
Kensington 72219 Mouse Logo
209 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
