Question about Miele Vacuums
My s5210/s5211 vacuum 14 months old makes a noise like a turbine
Veryloud motor noise like a jet turbine
  • Anonymous Mar 31, 2014
    When the vacuum is turned on it makes a very loud noise, similar to a jet turbine, seems to be coming from the motor, is there a good way to clean it.
    Novelist:
  • 97 Answers
You've got a 7 year motor warranty. Take it back to your dealer and have the motor replaced, unless you've been running it without filters or you've been using generic bags, which would have voided your motor warranty.
This is actually very rare: I've only ever seen one miele motor break that wasn't water related or related to negligence.
-R
Posted on Mar 09, 2009
Miele S5211 accidently pulled out the whole device that the bag is attached to.
Hi There I have made a video showing how to replace the bag holder it is not too hard to do.
Sep 17, 2013 | Miele S5211 Deep Black Vacuum Cleaner...
Problem - Dyson Vacuum - Turbine Head DC-23 I have the Dyson Turbine Head DC-23 Vacuum. I love my vacuum. I've had it for 13 months. I have had no problemwith it, until now. Now, every...
I'm sorry to hear you're having difficulties with your DC23's turbine head. If you haven't already got in touch with us directly, I'd encourage you to do so. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue you're experiencing, and will be able to recommend the best course of action. If necessary, we should be able to replace the turbine head under the 5 year warranty, as long as it's been used in accordance with the terms and conditions listed in the user guide.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 07, 2011 | Vacuums
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
My Hoover steam vac dual v's brushes will not spin and the square that the peg goes into wont spin either. There is suction but it is making a loud noise.
sometime when the brush is not turning their are less resistance to the motor, so it will turn allot faster than normal. The turbine gear assembly which connected to the brush assembly probably broken, all the gears are made out plastic and they can easily break,strip or worned over period of usage. the assembly cost around 20 bucks and it not that hard to replace and it not that hard to take it apart, just remember what goes where. I wonldn't surprise when taking the vacuum apart as you observed closely and inspect the brush unit and the turbine gear assembly you might easily spot what broken and need replacing. hope that help some; and if you don't want to fiddle with it, your local vacuum repair guy can probably do it for less than 40 bucks. you can go on-line vacuum parts.com
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Grinding
Are the brushes turning? If not, take the brush block out and see if they turn easily, if they do, is the shaft sticking up still there, or has it broked off. Turn on the unit while the brush block is out, the nosie still there? If not replace the brush block #48437029. If noise is still there, it could be the turbine #43191005 or even the motor #43576197.
Dec 13, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
Help!!!
hi pop in to here http://bissell.com/Search/FAQ.asp type tour querry and see if they can give you an answer
riz.
Nov 11, 2007 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
789 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
