Question about Refrigerators
How to install crisper support in whirlpool estate refrigerator after taking it out for cleaning.
SOURCE: Leaking Whirlpool refrigerator
I had a problem with water accumulating on the first shelf and and underneath the drawers in the bottom of the refrigerator. I traced it back to the overflow cup that is located inside the refrigerator in the middle of the top. NOT inside the freezer, but rather in the the refrigerator portion.
Unload the top shelf and place some paper towels near the back of the shelf to catch about a 1/2 cup of water. Gently grab the tab on the overflow cup and slide it towards you. I am willing to bet there is a large plug of mold inside the pipe on the cup that has been blocking the drainage.
Now is a good time to clean up the water under the drawers in the bottom of the fridge and while you are at it, clean the shelves.
Posted on Jun 01, 2008
SOURCE: Broken refrigerator drawer support pin
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
Posted on Nov 24, 2008
  • 531 Answers
SOURCE: water under crisper in my whirlpool refrigerator
your refrigerator door may be (ajar) or drain clogged
Posted on Apr 05, 2009
dmftrucker
  • 1922 Answers
SOURCE: Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Posted on Nov 02, 2009
arikrom
  • 528 Answers
SOURCE: whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Posted on Jan 01, 2010
Model ED25RF freezes items in bottom crisper drawer. Other parts and drawers ok.
We run across customers that have this trouble from time to time with there refrigerators. The first question i usually ask if the have changed the temperature setting recently. If not try a over night defrost, open the doors and unplug the refrigerator over night. That seems to take care of the problem. Its also a good time to give it a good cleaning. Don't forget to clean your condenser coils to.
If it helped join or Google Plus please.
On Time Appliance Google
Jun 30, 2015 | Whirlpool Refrigerators
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking onto the floor and down the back of refrigerator to the bottom under the vegetable crispers?
You have a problem with the auto defrost drain system.Carefully take off the cover by the light and control and see if you can clean out the drain. Sometimes you can get to it from behind the refrig. but that means you have to move the refrig out from the wall.Hope you find this helpful.
Jun 12, 2011 | Whirlpool Refrigerators
Whirlpool refrigerator has water pooling under crisper
  4. put all back
Dec 29, 2009 | Refrigerators
Cleaning refrigerator & have a bar I don't know where it goes Whirlpool Model - ET1CHMXKQ02
If the bar is long , it probably fits inside the crisper cover which has a U shaped slot for the bar to slide into .
Aug 25, 2009 | Whirlpool Refrigerators
Underneath the crispers is full of water sometimes even freezes Underneath the crispers water collects, but it does not freeze.
Here is a link to help you resolve the problem I also have an even better link but on-line is moving slow at moment. Anyway you will need to take the part out from back and clean the blockage., Let me know if this helps, Sea breeze
http://appliancejunk.com/forums/index.php?topic=1309.0#top
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
System was off
Hello. Did you try running the water through the door until it becomes room temperature? This will completely flush out the water resouvior in the fresh food section. When it comes to the ice tasting bad, a lot of the time it is from something that has gone bad in or behind the crisper drawers. Take the drawers out and check. You may be thinking how can something in the frig compartment effect the ice? The frig is cooled by the freezer by a opening in the top and bottom of the center divider. Hopefully this helps.
Dec 03, 2008 | Estate TS25AFXK Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
