Question about Acer Aspire 5680 Notebook
My FN F5 key do not show the screen to be changed
Acer 5680 My FN F5 key do not show the screen to be changed
I have an Acer Aspire5517 only for a few months, it happened in recent that the screen looks like dead and shows nothing when I turn the power on. can not use F8 or F10 keys during booting, please help
yes, try use f8 and see if you can go into safe mode and check what is wrong with the dsiplay screen.
try changing the screen mode to by press the "fn" key + F5 and use an external screen to confirm whether the laptop is working properly or not.
May 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Connectted to big screen monitor, the button Fn and F5 not work. what is the reason?
What is the screen Resolution set to on your current Display?
Try setting your current Display to 1024x768, then try the FN+F5 key
this might work. IF your current Display is set to high the other screen might not show any picture at all.
Feb 25, 2010 | Acer Computers & Internet
I connected Samsung SyncMaster930b to Acer 3610. How can I switch to big screen or see both. Tnanks
It depends on your video card if the split screen feature is supported. Better check its documentation. Or you may opt to check it in Display Properties (Windows Platform)
Dec 07, 2009 | Acer Aspire 3610 Notebook
My acer laptop screen crack and I trid to coonnect it to monitor
You will more than likely need to enable the external monitor port of the laptop, using the Fn key, and one of the F Keys along the top. On the Travelmate's it's usually F5, so hold the Fn Key and press F5, with the monitor connected and powered up. You should find it springs into life. If not, you need to look for the monitor key on your laptop. It will look like an F Key along the top, but will have a little symbol showing two monitors on it (two rounded edge rectangles).
Mar 04, 2009 | Acer Aspire 5050-3242 Notebook
Fn F5 key in my Travelmate2310 stopped working
Was Fn+F5 working before? Why do you 'have to use with external display", because LCD no display any more or...?
If non above, you better check from BIOS and chang display to Both LCD and VGA.
If Fn+F5 was working before but not now, could be something else wrong... I need know more details....
Nov 12, 2008 | Acer TravelMate 2300 Notebook
Function+F5 not working
Check bios if you disabled somehow the fn key.
Jan 01, 2008 | Acer Aspire 5004WLMi Notebook
Acer travelmate 4200 'F5' key not working
Following an advice in this forum I loaded the launch manager for the travelmate 6592, installed it and It put working on the silver P key of the laptop, i.e. the launch manager, and at the same time the fn+F5 key started to working on again. For a long time this key was disappeared from me laptop, just the same time that the fn+F5 key didn`t work.
Jan 01, 2008 | Computers & Internet
Acer Aspire 5680 Notebook Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
