How do I fix a squeak in a hardwood floor
squeeks in a hardwood floor most times are caused by the hardwood separating from the underlayment (board) and hence it piviots on a nail and you got a squeak !! , there are a few ways to fix this "
if the squeak is located in a spot that is accessible from under the floor , see if you can determine what hardwood and underlayment thickness is , look around behind a floor casement or around a doorway trim with flashlight , find a wood screw that is 1/8 less than this number (two added together ) also locate a drill that is just size of screw shaft you found , drill hole from under the floor (underlayment) just deep enough to penetrate the underlayment (3/4 inch or so) use tape on bit as a gauge , don't drill into hard wood then drive wood screw into hole , the idea is that screw will pull hardwood down to underlayment , screw cant grip underlayment due to hole so this is piviot point . a shot of wood glue on screw threads helps it from coming out too !!
now if space under squeak isn't accessible this is a bit harder but not impossible to do , there are a few special items to get first , one is a glue injector needle !! this typically is used making wood furniture but I have seen a meat basting syringe used in a pinch too, locate the spot close to squeak from top , using a small drill dril down at seam (not in middle of board) just deep enough to hardwood Not underlayment , load up your syringe with wood glue and force it down into hole with needle takes some force to do this , wipe off spilled glue and set a heavy object on this spot for 24 hrs object can be a lg pile of books or I use cement blocks (4) set on a piece of butcher paper (not cardboard) after 24 hr remove blocks and ck for squeak if none use hard setting tinted wood filler to plug hole you made and top off with a dot of varnish to seal it when dry and flat if you still detect the squeak then move over a board or two and repeat process till squeak is gone
